tnc110
- Jan 5, 2015
- Sidewinder BTX SE, SRXs
I used the Artic Cat kit on my Viper. It was a simple plug-and-play. Does the same kit work on The Sidewinder?
Yes
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Heat demon. 70 bucks no brainer.
2300 miles this year on mine worked great!. Actually can not leave it on just cycle on and off. It gets damn hot.. But its awesome on those really cold mornings. I ride early
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
wkeggenhoff
- Dec 20, 2007
- Ajax,Onatrio, Canada
- 2006 Yamaha Apex RTX
YOU CAN GET THE HEAT DEMON WITH A HIGH AND LOW AS WELL. HAD MINE BURN UP SEAT AND PANTS LAST YEAR.THERE WAS A BIG RECALL ON THEM
AGREED TOO HOT WITH JUST THE ONE TEMP ONE. USE MINE ON LOW ALL THE TIME, HIGH NOT REQUIRED
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Ted Jennety Clutching, jetting, air box mod.
Arctic Cat Z1 Turbo 128" Rear Suspension
128" Hacksaw 1" track.
Heated seat
Is the Heat Demon weather proof? I had an ad on unit that we use in the automotive industry. On the last ride last year it rained hard and burned the unit out along with my seat cover and bibs.
The RX1 seat cover has little holes in it.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Should never happen with a inline fuse in place.YOU CAN GET THE HEAT DEMON WITH A HIGH AND LOW AS WELL. HAD MINE BURN UP SEAT AND PANTS LAST YEAR.THERE WAS A BIG RECALL ON THEM
I have the Moose brand one with one setting. Its just perfect temp for Railroad grades. Everywhere else it never gets warm enough to notice since my butt isn't on the seat long enough!
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Heated seat
I will have to check. Thought I put a fuse in it but maybe not.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Well its crazy they do not mention it in the install directions.. I put a 2 or 3 amp inline in mine.. I cant remember exactly. I even contacted them about putting one in.. they did contact me back.. Kinda strange they dont recommend the fuse.. My riding buddy is a electrical engineer. SO in went the fuseI will have to check. Thought I put a fuse in it but maybe not.
Team Lazy
- Jan 22, 2016
- Barrie
- Viper XTX
Bravo 250
WHY ARE YOU YELLING?
tnc110
- Jan 5, 2015
I don't see the two wire plug that the Viper has to get power. On the Viper it was just behind oil tank.
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700, 2023 Polaris Boost VR-129
- Niles, Oh
Hey guys, I'm thinking about adding a heated seat to my Apex. Trying to choose between adding the winder element or the demon. 30 watts for the demon doesn't sound like much.
Anybody have experience with both that can make a recommendation?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
I am not impressed by the original one! You better go heat demon, i have it on my 4wheeler a lot betterHey guys, I'm thinking about adding a heated seat to my Apex. Trying to choose between adding the winder element or the demon. 30 watts for the demon doesn't sound like much.
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
I got a pretty hot #*$&@ so I don’t need it.
- 8K
