stgdz
- Mar 27, 2021
- Buffalo MN
Turboflash
- Mar 18, 2019
- Southern MN
You're all set.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
same ones i got with tool works perfect.
stgdz
- Mar 27, 2021
- Buffalo MN
So according to this chart
www.onallcylinders.com
An 8an fitting requires about 25 ftlbs of torque. That seems a bit high. These are the fittings I'm using https://www.urotuning.com/products/...rb-fitting-8an-orb-5-16?variant=8311027433527
Apologies for all these questions, it's the first time I'm doing this.
AN Fittings Torque Chart for Automotive Plumbing
This handy chart gives you all the torque specs for each AN fitting size that you'll commonly see in vehicle engine plumbing applications.
Turboflash
- Mar 18, 2019
- Southern MN
Your pic shows an o-ring fitting, not a 37 deg flare AN fitting the torque chart was made for. I hope you have the right filter for this o-ring type male hose barb fitting.
You'll feel the fitting bottom into the filter - it will just stop. IMO, once it bottoms, I'd put about 15-18 ft lbs on it. With oring, it won't leak as long as it doesn't come loose.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
The fuel filter referenced in this thread is no longer available. Would this one work? It shows 88 GPH at 61.4psi and it already comes with 5/16" fittings. Seems like 88 GPH would be enough.
https://www.holley.com/products/plu...ystem_components/fuel_filters/parts/731155ERL
I would also buy their Vapor Guard hose clamps but I don't know if the hose on my 2017 is actually 5/16" ID (which is just slightly smaller than 8mm... 7.9375mm to be exact).
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I can't open that attachment
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Stand by. I just realized that. I got a replacement
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I think I found the one you were referencing.
DeatschWerks 5/16in 10 Micron 55mm In-Line Fuel Filter Kit
In-line fuel filter element and housing kit, stainless steel 5 micron, 5/16in hose barb, 55mm. Universal
Are you saying that you think that one is better than the Earl's one that I posted? If so, why?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Lethal performance. I think is where I ordered it. Use the code.
Fords4life
- Dec 7, 2021
- South Dakota
There fuel pumps work well also instead of a walbro....if anybody is interested...amazon is where i get mine in the past, less worry about china knock off's of walbros.This has the barbed ends. Easy pease.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
The Earl's one that I posted also has "barbed" fittings... just a different type of barb. Regardless, since I wouldn't be using their Vapor Guard hose, I will probably just order the one that you posted... but from Elite Race Fab (cheaper even after the coupon).This has the barbed ends. Easy pease.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
That DeatschWerks DWFF55c inline filter shows that it flow 200 LPH which converts to 52.83 GPH. Is that enough for the stock fuel pump? I see that the Walbro GSS342 that most go to when they upgrade is rated for 255 LPH. I don't have a need for the Walbro pump at this time with my TD PowerTrail PM tune but I have no idea what the stock fuel pump flowsThis has the barbed ends. Easy pease.
Are you using this filter (or anyone that you know)?
- 6K
