They make a tool to install that hard line on filter using no clamps. It’s just a reminder to not trust them. Since this happened to me I look for leaks before every weekend ride and if I smell fuel will stop and fix immediately or let sled sit.No way to install a inline fuel filter without clamps? I understand the molded plastic fuel line and why they did it. But how else can you install a filter?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
8 AN O Ring Boss to 5 | 16" Hose Barb Fitting
These unique fittings feature a -8 AN o ring boss port on one end | and a 5 | 16" hose barb on the other end.
I'm about 99% sure theses are the ones I used on the ends of the fuel filter itself.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
So the input and outlet holes on the filter are not machined with tapered pipe tapped threads which requires the oring? I would have thought it would have a tapered pipe thread in it. That would allow you to just thread the fittings in with thread sealer![]()
These unique fittings feature a -8 AN o ring boss port on one end | and a 5 | 16" hose barb on the other end.www.urotuning.com
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I do not recall. And to be honest I was slightly unsure on what fittings to use.. I used the one I linked to.. No leaks this season on it.So the input and outlet holes on the filter are not machined with tapered pipe tapped threads which requires the oring? I would have thought it would have a tapered pipe thread in it. That would allow you to just thread the fittings in with thread sealer
.. But I was definitely checking and keeping a eye on that filter and fittings.. I even drew a paint line on them so I would see if the fitting loosened up ever so slightly.
Turboflash
- Mar 18, 2019
- Southern MN
Machined threads w silicone o-rings. Filter made for race car applications, some up to 100 psi EFI. I wouldn't trust that plastic fuel line even though it's used allot under the hood in modern automotive applications. Be careful using clamps because clamping could crush hard plastic out of round and cause it to leak or break.So the input and outlet holes on the filter are not machined with tapered pipe tapped threads which requires the oring? I would have thought it would have a tapered pipe thread in it. That would allow you to just thread the fittings in with thread sealer
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
The straight fittings with an o-ring will handle higher pressure than tapered pipe thread. This is why you never see tapered threads for high-pressure hydraulic fittings. If they ARE threaded and not a JIC thread, they typically are a straight thread with a copper or rubber/steel crush washer.So the input and outlet holes on the filter are not machined with tapered pipe tapped threads which requires the oring? I would have thought it would have a tapered pipe thread in it. That would allow you to just thread the fittings in with thread sealer
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
The only way would be to find a filter than had the -AN male fittings machined into it. Then, you would need to order pre-made lengths of hose that have the -AN female fittings machine crimped on the ends. At least that is the only way I can think of.No way to install a inline fuel filter without clamps? I understand the molded plastic fuel line and why they did it. But how else can you install a filter?
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
You do realize that the fuel hose is clamped on the fuel pump outlet, right? At least that is the way it is on my 17 Sidewinder.Just a heads up for you guys adding a filter. Dont trust clamps. Any clamps. I believe mine failed from corrosion jacking. Dont know but think of all the newer vehicles. No clamps. No issues. Just saying.
Recalled Fuel Line Leak
Not good! Knew I smelled gas last night daughter said she didn’t.ty4stroke.com
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I think he is saying don't trust them over time.. The newer Plastic like fuel line is cut and sealed/crimped so to speak to size and length. It has no clamps of any kind on it. And is not flexible at all(its got the proper bends built in). This was what they went to on the newer sleds.. Not sure what year it started but when they went to another gas line material with no clamps they eliminated the fuel filter(from viper) (sidewinder never had one).. Me personally I will take my chances with clamps and value the inline fuel filter protecting the injectors from build up and loss of efficiency.. I think a guy could replace the fuel line and clamps every 2-3 years? That may sound a little overkill but when your dealing with a gas bomb(potentially) its money well spent.. Buy 25 feet of the gas line and a bunch of clamps. Its not a big job at all and maybe some peace of mind?You do realize that the fuel hose is clamped on the fuel pump outlet, right? At least that is the way it is on my 17 Sidewinder.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
That leak in the link was also on a steel filter. The Viper fuel filters are steel. The filter you installed and the fitting are anodized aluminum. Those anodized fittings are not going to corrode unless they get scratched through the anodizing.I think he is saying don't trust them over time.. The newer Plastic like fuel line is cut and sealed/crimped so to speak to size and length. It has no clamps of any kind on it. And is not flexible at all(its got the proper bends built in). This was what they went to on the newer sleds.. Not sure what year it started but when they went to another gas line material with no clamps they eliminated the fuel filter(from viper) (sidewinder never had one).. Me personally I will take my chances with clamps and value the inline fuel filter protecting the injectors from build up and loss of efficiency.. I think a guy could replace the fuel line and clamps every 2-3 years? That may sound a little overkill but when your dealing with a gas bomb(potentially) its money well spent.. Buy 25 feet of the gas line and a bunch of clamps. Its not a big job at all and maybe some peace of mind?
I agree. But inspect religiously. That’s all.That leak in the link was also on a steel filter. The Viper fuel filters are steel. The filter you installed and the fitting are anodized aluminum. Those anodized fittings are not going to corrode unless they get scratched through the anodizing.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Did the Apex/Vectors have any secondary fuel filters? These machines are racking some very high mileage and I never heard of a fuel injector being blocked or a fuel filter needing to be changed.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Just a little bit overboard,
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
If you run them tuned 17+ psi. on cold days(o degrees F) they are maxed out on injectors. Below zero is even more critical. Maxed out injectors that have any restrictions(dirty) will throw a smaller percentage of fuel and in turn raise your AFR numbers = possible lean deto and engine damage. Guys are running a lot closer to the edge of safety then they think especially in colder weather.
Turboflash
- Mar 18, 2019
- Southern MN
Absolutely positively.If you run them tuned 17+ psi. on cold days(o degrees F) they are maxed out on injectors. Below zero is even more critical. Maxed out injectors that have any restrictions(dirty) will throw a smaller percentage of fuel and in turn raise your AFR numbers = possible lean deto and engine damage. Guys are running a lot closer to the edge of safety then they think especially in colder weather.
- 6K
