insane
How much timing can I add to my apex? I have a .060 shimmed head water/meth injection by hurricane and a s/c at about 10-12 psi. How much timing can I add at 16psi.
Need for Speed 2
None at 16 but a bunch below 5 psi, at 16 I would be pulling 3 especially on a super where the intake charge is usually warmer than a turbo
insane
Need for Speed 2 said:None at 16 but a bunch below 5 psi, at 16 I would be pulling 3 especially on a super where the intake charge is usually warmer than a turbo
Thanks. I am using water/meth and that is supposed to keep the temps down so you can advance timing at those boost #. With a shimmed head and lower cr that will factor in as well. I know without water/meth I can add some timing up to about 7 psi and then go back to stock or even pull some at 10-12 psi. Also another question is what is the best fuel to run with water-meth and a shimmed head up to 10-12 psi and 16 psi? I plan on talking to Dave at Hurricane but I want to start a post as alot of other guys are running meth.
Need for Speed 2
I ran 87 octane with my meth on my nytro and apex, I wouldnt get to carried away addind timing under boost with the super, you can pull some fuel out and run a.f.s into 12.5 -12.8 and make power but watch the timing part , I really dont like pushing the super I did have a castastrphic event with mine and I feel a turbo would have survived way beyond the supers threshold. What are you doing trail /lakes,
HURRICANE
We are finding that the Apex needs the stock timing with the boost.If you are boosting to 10to12psi,I wouldn't pull any timing and as Keven said add some timing below 5000rpm
