gpxsrx
- Dec 15, 2009
- way to many 2 strokes
Where is the best place to connect aem AFR gauge to a power wire source. Thanks Bruce
Right from the battery with a relay that powers up off headlight.
0llll0
GO JETS GO
- Mar 9, 2014
- Winnipeg, Manitoba
- 2014 Sr Viper LTX-SE
Curtis Chambers
- Nov 19, 2014
- 2015 SRViper R-tx-Le
Add fuse if coming off battery
gpxsrx
- Dec 15, 2009
Simple and clean thanks BruceI used the power from the back of the 12v socket(cigarette lighter). Used piggyback sta-kons.
I have tried this before but some O2 Sensors don't like that power source... just an FYI, it can mess up the gauges output numbers.
gpxsrx
- Dec 15, 2009
I'm using a AEM 30-4110 gauge. Thanks Mr Sled for the heads up reading installation instructions.I have tried this before but some O2 Sensors don't like that power source... just an FYI, it can mess up the gauges output numbers.
Quote: Connect to a switched 10-18 volt power source utilizing a 10a fuse. I have the sled all tore apart checking everything out, reversed cooling fan rotation so I will make a harness for AEM gauge with 10 a fuse.Thanks again Bruce
0llll0
GO JETS GO
- Mar 9, 2014
OSP makes wiring harness kits to power one or two aem gauges and they power it from the back of the 12v socket, you would think that they wouldn't do that if it causes problems but who knows maybe it could. I know mine seems to work fine.
