Aftermarket Belt Guard Needed!?
Do you have or not an aftermarket belt guard? What was you experience? Select two responses:
  • No aftermarket belt guard, just stock upper guard
    Votes: 7 21.9%
  • I have an aftermarket lower belt guard
    Votes: 23 71.9%
  • Blown belts before but NO damage to stock plastic, caliper or bad marks on belt guard (if equipped)
    Votes: 7 21.9%
  • Blown belts before WITH damage to stock plastic or bad marks on aftermarket belt guard (if equipped)
    Votes: 3 9.4%
  • Blowing belts what's that?
    Votes: 9 28.1%
  • Total voters
    32
Trying to evaluate the need for a aftermarket lower belt guard on stock Sidewinders to lets say max 240hp tunes. As I understand most bigger tunes runs higher risk.
I wouldn't even consider running a brand new stock sled without one. It just isn't worth the risk. Blew my 1st belt on the 2018 when it was new around 300 miles. What a mess. Ended up having to be towed back. I have had a few different belt guards, but I have to say, the Precision EFI belt guard is by far the nicest. It pains me to say that, and it is the only product of theirs I will ever recommend again given that they blatantly copied one of Travis' designs from Barn of Parts.
Agree with those who state belts failures are not always because belt is too hot. I too have a Razorback IR temp gage but that only tells me current belt temp and, if it ever gets too hot (which it never does) then I can let off. My belt temps on Stage 3 are usually only 160-170 while on flipper hard.
I made my own full-circle belt guard (6061-T6 alum) - wraps around front and back, completely surrounds clutch and belt. Easily removable. See pic.
