SteelerJim
are all of you running with limiter straps in last hole? Aggressive snotrackers?
sledheadgeorge
are all of you running with limiter straps in last hole? Agressive snotrackers?
Aggressive Snowtrackers and limiters let out all the way. Front shock on the rear skid has a RX-1 rear skid spring from the front shock.
engineman
- Feb 19, 2013
- Between Hastings & Redwing MN
- 2009 Apex LTX, 2010 Vector LTX GT, 1996 Indy 500 SKS
My limiter straps are in the stock location and I am running Agressive Snowtrackers. I was able to let out the transfer rod some and still had good performance. Probably will try letting out transfer rod some more but season is over here in MN so it will have to be next year. Front springs are 1 turn from full loose when shocks are fully extended.
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Has anyone tried the Apex Mountain skis with some other carbides with good success? Like Shapers or Triple points?
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
Ya anyone?
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
I had 6" Bergstrum Triple points on my Slydog powder hounds and it turned beautifully and tracked straight. but believe it or not the conditions were so bad in 2016 that I wore them almost flat !
The set before that had over 3k on them. So after seeing how bad the Triple points were. I made a switch to the Snowtrackers Semi Aggressive and found the steering effort went down but the tracking was excellent . I ran 6" shaper bars on the Slydog for a couple of months but the steering effort was to much.
At this point the Snowtrackers and the Triple points are the only carbides I will use . They are about the same price. Bergstrum use to offer up repeat customers a discount but haven't seen any specials from him for about 4 years....
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
If you haven't made a purchase yet there is some Yamaha mountain single keel skis available cheap on this site.
Those and snow trackers and you would have the best of all worlds. I have snow trackers aggressive, thousands of miles on a Bergstrom 8 triple points both good, I would give the handling nod to Sno Trackers to soon to tell on the longevity the Bergstrom's lasted forever -7 k miles.
snobill
- Nov 4, 2012
- 2012 apex xtx
That’s my plan thanks, I was just wondering if any other carbide would work good or the same
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I have tried most carbides on the market and nothing holds a candle to snow trackers in my opinion. I just don't even think about carbides anymore after I found them.That’s my plan thanks, I was just wondering if any other carbide would work good or the same
snobill
- Nov 4, 2012
- 2012 apex xtx
Thanks sounds like snowtrackers aggressive for me !
Augie
- Sep 2, 2016
- S.WI
- 98 700 VMAX
06 ATTAK
20 X2 XTR
21 RMAX2 LE
where y'allI have tried most carbides on the market and nothing holds a candle to snow trackers in my opinion. I just don't even think about carbides anymore after I found them.
Where Y'all ordering your snow trackers, I did a search and I see you can even get them at Walmart?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I have never seen them there. Port Yamaha or Travis @ barn of parts.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
last I seen Travis had a set that he demoed and was selling at a discount.
Augie
- Sep 2, 2016
- S.WI
- 98 700 VMAX
06 ATTAK
20 X2 XTR
21 RMAX2 LE
Thanks, I wonder if They have a set that will fit SLP Skis with dual runners ?
snobill
- Nov 4, 2012
- 2012 apex xtx
So I got my mountain skis do I need different hardware or just bolt them on ?
