Rash
there seems to be a lot of differente styles of C&A skis
http://www.caultrapro.com/products.php
witch ones are best on the ATTAK to stop darting, and max cornering, occasionnal deep snow...
Extreme advantage?
RASH
Extreme advantage?
RASH
Starry Knight
Well, it seems like the rule of thumb is that ANYTHING is better than the stock ski's. I am leaning towards the idea that ZipClean had, and using the APEX mountain ski's. I really don't go off trail much, but it will bug me if I know I can't do it.
Ground Blizzard
Attak said:HI attak,i am interested in how well your new mountains work for carving tight turns on packed trails,plus all the other types of conditions we drive in,and you said that you just buy the ski bottoms and install them on stock set up,how much did they the bottoms cost ya,and was the install straight foward,i mean no cutting or grinding?? thanks Pete
You don't need to do anything. Just remove your old ones, transfer the parts over and install the new ones. The bottoms are about $94.00 per side. I don't have snow yet so I can't tell you how they work.
Not quite, just put the mtn ski's on my Rage and you'll need, longer boltx2, bushingsx2 and 4 collar's but it is very easy to do.
Starry Knight
Good to know (about the extra parts). Anybody have any reviews of the mountain skis yet???
Attak
[/color]
Maybe you did for your Rage. I didn't need anything for my Attak.
stormchaser
Attak said:Hey Attack-let me know how them mountain skis work on packed trails, I am thinking on doing the same-I'm mostly worried about darting. Thanks
[/color]
apexer06
Yama-Crazy
I dunno but so far I'm very happy with what I have ..stock skis with Bergstrom 6" carbides with his shims, no darting since the shims and no studs!
jimmie d
Last three sleds have had Simmons, just ordered Slydogs.
Jim
Jim
LazyBastard
favarcat
[/color]
My dealer just swapped my stock skis for the Yamaha mountain skis for $10 each. But they DO need the 4 collars, 2 longer bushings, and 2 bolts.
trekkr
- Aug 28, 2003
Just stumbled onto this thread, don't post here much. Look for a new adjustable-keel ski from Yam next year or year after. Not sure if it will be wider for flotation, or how easy it will be to adjust, but it will certainly help any darting/pushing/carving issue, on any suspension setup, in any condition.
stormchaser
[/color]
OK' Do we need the extra parts or not? One person says yes-the other no.
favarcat
[/color]
Yes, we need the extra parts. I have the skis sitting next to me right now and the Attak in the garage without skis on it. And we just got a foot of snow. I ordered the extra parts, and they should be in Tues.
Here is a picture of the Mountain ski. Also a picture of the ski with the stock ski mounting bolt into it. It is too short to go all the way thru.
stormchaser
Thanks favarcat-looks like I'll have to order more parts. Being wider is this going to make them sloppy? Isn't there going to be play on each side of the mount?
