stingray719
Ive seen a number of guys cut out the bottom of the box. i was wondering if this intake kit would be any different as it looks like it uses a different approach than the original intake hole in the box?
I just saw this on ebay and the question came to mind.
Coming in from the side causes turbulence, ask for dyno chart on that box and note where power is made.
It's definitely mid range power. Stingray what do you think about adding another snorkel to other side? Would that cause more turbulence or the two cancel each other out? I don't want to abandon the Excell since it definitely gave cooler intake temps but the speed at which my divider wore has almost got to show there is massive turbulence going on in there.Coming in from the side causes turbulence, ask for dyno chart on that box and note where power is made.
stingray719
I liked the mod to mine in the "my airbox mod" thread where he removed ALL the nose not just cut out the piece I did, but worry about the frog skin coming apart without the extra plastic support kept me from trying it. The answer may be my mod with a hose to it like the mid 2000's Arctic Cat did. Remember those? Looked like an RV sewer hose going from nose to air box. Has to be indirect air injection though as many known issues with ram air scoop on sleds.
I remember that. It was on Firecats. Air came in on sides of a piece on hood. Was a frog skin or some filter in between it and big hose. My buddies plugged with snow dust often. What about getting cool air from the cowl like 2st cats? Holes are there.I liked the mod to mine in the "my airbox mod" thread where he removed ALL the nose not just cut out the piece I did, but worry about the frog skin coming apart without the extra plastic support kept me from trying it. The answer may be my mod with a hose to it like the mid 2000's Arctic Cat did. Remember those? Looked like an RV sewer hose going from nose to air box. Has to be indirect air injection though as many known issues with ram air scoop on sleds.
stingray719
Without the high air velocity from the nose, interrupting that flow will cause turbulence....unless you run that hose all the way down and then I do not know if you will gain enough HP to make it worth it. The holes in my first air box mod worked better for mod sleds as the need for more air outweighs the turbulence factor but for stock sleds losing the high velocity air flow cause loss of throttle response and top end.....at leas that is what my testing both boxes side by side has shown. Now that being said the difference in the two boxes is very small and takes riding both side by side to tell. As in how would you quantify throttle response if you dyno tested it?
Please do keep trying Cannondale and if you find a large improvement I will be happy. I do this to share with all for free and nothing is better than people improving on your idea.
stingray719
Went to Ebay to see this, they want you to pay $249.00 for those bolt on screens....LOL!
1. why would you pay $249.00 for a mod you can do free
2. Side air like they have is going to be good for power under 7k.....you need power under 7k when your clutch keeps you above 7k?
3. Thunder Products sells very similar vents for $39.90
I would bet a bunch of members here would mod anybody's box for them for #249.00
JUST KIDDING! I developed my air box mod so all could enjoy for free and was not trying to get anybody to set up a box mod business.
- Apr 14, 2003
- Hessel, Michigan
And it does work
dlinebacker36w
Where's the link to show how to do it I'm ready to try lol
Sent from my XT1254 using Tapatalk
- Apr 14, 2003
- Hessel, Michigan
Heat pcv divider and bend over to minimize turbulence, as per first pic....
Remove snorkel from the lower air opening and do not reinstall.
Cut out are as per second pic but be careful you don't damage frogskin. This one looks a little rough as pic was taken before finish work.
EDIT 10/05/2015: Jim from EVO says the EVO 2.5 ECU flash will allow this mod to be used with an aftermarket can. Gives you the proper fueling and no starter kickback along with rev limiter raise. Link below.
http://www.evopowersports.com/Yamah...archPage=2&searchRank=salesrank&searchSize=12
EDIT: Please note in the picture that the raised ledge is also cut off around the hole, sorry if that is not clear.
Studroes144
- Oct 30, 2013
dlinebacker36w
Good video thanks
birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
I left the frog skin support in there. Here is how mine looks like
Birkebeiner
Birkebeiner
Studroes144
- Oct 30, 2013
Birkebeiner
Looks nice, I have a cat 7000 I'm putting one on right now, had it out for about 10 miles today, only pulling 8700, wanna get the modded air box on and go right back out and see what it does for rpm
Alsim
- Oct 6, 2014
- LTX SE 2018
Let us know !
Studroes144
- Oct 30, 2013
Let us know !![]()
It works!! Check out my new post.
- Status
