thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
would be better then nothing but snow can go thru a screen
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
What could I use
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
Would screen and foam work like the screen holding the foam in
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
sure I would find a old 2 stroke airbox that has the foam still on it and cut it to fit. i see no reason why you couldn't use door screen to hold it in.
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
Ya that what I was thinking I go look at lows see if they have foam
yamahahaapex
not fine enough but better than nothing
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
So a foam air filter will not work I want some thing that will so no snow will get in there and how can you tell if ur sliders r no good
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
Air box prob fixed
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
looks good sliders are worn out when you can fit a 10mm wrench over the profile at any point. any more and you are good for many miles.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Window screen is too coarse, (it will allow snow through) you need something like the frog skin.
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
I look at that frogzskin look some really good won't let what're in or any thing when I get in can I take the air filter of and just use the frogzskin to cover the hole or no use the air filter to
yamahahaapex
needs to be finer than a standard window screen
