Air box probs
would be better then nothing but snow can go thru a screen
Would screen and foam work like the screen holding the foam in
sure I would find a old 2 stroke airbox that has the foam still on it and cut it to fit. i see no reason why you couldn't use door screen to hold it in.
Ya that what I was thinking I go look at lows see if they have foam
So a foam air filter will not work I want some thing that will so no snow will get in there and how can you tell if ur sliders r no good
not fine enough but better than nothing
Air box prob fixed
looks good sliders are worn out when you can fit a 10mm wrench over the profile at any point. any more and you are good for many miles.
Window screen is too coarse, (it will allow snow through) you need something like the frog skin.
I look at that frogzskin look some really good won't let what're in or any thing when I get in can I take the air filter of and just use the frogzskin to cover the hole or no use the air filter to
