SHAMARKEN
- Aug 21, 2003
- Johnstown,Ont
- Z1Turbo
what's the trick to keep the air box mounted on the carbs???
seems like after every ride I have to remount the air box juat seems to slide of the carbs ... I'm I tightening the clamps to much???or do i need to replace the boots??
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
I find it easiest to take the lid off and work them on from the inside of the boot
SHAMARKEN said:what's the trick to keep the air box mounted on the carbs???
Take the airbox off. Take the clamps off the rubber grommets. Clean up the rubbers, put a bead of silicone on the rubbers where the clamps go and reinstall the clamps. Let it dry for 24 hours and install on sled put a bit of oil on the inside lip of the rubbers so they slip on easy. Make sure clamps stay square when tightening down no need to tighten too much just enough to make a seal. You should be good to good to go.
nards444
lol yeah whoever came up with the design on these should be shot
SHodas
easiest way, trash the airbox and put K & N filters on it with larger main jets, best thing I ever did. fuel milage stayed the same.
Indy
absolutley!
SHAMARKEN
- Aug 21, 2003
- Johnstown,Ont
- Z1Turbo
Sled Dog said:SHAMARKEN said:what's the trick to keep the air box mounted on the carbs???
Perfect !! I'll give this a try!
SHodas said:easiest way, trash the airbox and put K & N filters on it with larger main jets, best thing I ever did. fuel milage stayed the same.
If you like the noise and the extra expense yes he can do the k&N filters. He can do my air box mod and get the same if not better performance without the cost and without the extra loud intake noise.
SHAMARKEN
- Aug 21, 2003
- Johnstown,Ont
- Z1Turbo
I plan on doing the airbox mod this summer,
still getti8ng use to the 4 strokea big difference coming off my srx....starting all over again and relearning a new beast!
Indy
Sled dog-has you hole cutting mod been dyno'd or is just seat of the pants results? Just curious.
Not dyno'd but in real world before and after racing the same sleds there is a most definite increase in performance. Enough that you can tell the difference first ride with the mod.
Indy
is the mod only cutting the holes?
did you ever install or ride a sled with the ECP kit?
I would like the intake noise that you spoke of above, but honestly, I do not hear any difference unless the hood is up.
This kit has been dyno'd and proven, back when the Rx1's came out, it was a mad rush to get the kits installed, incredible pull through out. If you are getting the same results with just holes, that is impressive.
It is jetting and opening up the air box. Yes I had the ECP kit installed and took it off because it was freezing and choking the engine every time I went off trail. I then kept the jetting and opened up the air box gradually until my plugs were burning a light rustiy color and left it there. I found the air box was as good and could even be better than the filters performance wise and my gas mileage acutally went up. Go to Mod Results and check it out its a sticky.
Indy
will do
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I have run the filter kit and now run a modded airbox. Both seem to give the same performance. I too had issues with my K&N's icing up. No problem with the airbox mod.
