swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Sled has a surge around 8 to13 mph, just the speed needed to navigate gas stations, load in trailer or creep around tight spots. Its acted like this since day 1. It feels, fuel or clutch related. 2020 LTX-GT. It always starts, idles,revs, runs good. Warm, hot, cold makes no difference. Any ideas ?
Pstn head
Possibly primary spring broken.
Turboflash
- Mar 18, 2019
- Southern MN
Check primary weights to see if there are worn spots.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
I will look, but have my doubts. Thanks.Possibly primary spring broken.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
With 600 miles ? Sheesh, I hope not. Have Thunder weights ready to go in , if need be. Thanks.Check primary weights to see if there are worn spots.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I just went in the shop to have a look at the stock weights. They have a stall on them (hump built in). What happens is it travels a bit and weights swing out over that hump and it will feel like it shits up and the RPM drops and you'll get what you are calling a surge. Belt deflection tight or loose will change this effect somewhat.
In other words, it's designed this way and normal. A weight without this hump, or the hump being moved will act differently.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Thanks for the explanation. I would have NEVER figured that out. So a simple weight change can make this go away ? Thanks Knapp.
KnappAttack
- Feb 19, 2004
- Welch MN
It can, but also know that some aftermarket weights also have a stall built into them. You can also grind the stall down to loose that effect, but know that little changes make a big difference when grinding on the face of the weight, they all 3 need to be perfect if you decide to grind them down, you'll just sand the hump off to get rid of that effect, but don't go too far into the beginning shift portion of the weight or you'll get more belt slippage.
Honestly I wouldn't touch them if you don't know what you are doing with them. I've seen lots of guys mess up the weights when they start grinding on them.
- 40K
