yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I am thinking of tig welding the hole in the rear section of the rear skid mount and redrilling the hole and replacing the front section of the mount so I don't have to drill out all the structural rivets running up the tunnel!!
Has anyone done this?
RCk
- Dec 12, 2014
- Tughill, NY
- 2020 Sidewinder LTX-LE 2015 Apex XTX , 2013 RS Venture GT,09 RS Venture GT .05 RX Warrior
- Tughill, NY
Can you just weld a washer or something in the right spot?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Good thinkingCan you just weld a washer or something in the right spot?
RAMSOMAIR
I’d tig weld a washer to the outside. Do both sides at the same side so they match. Just my OCD!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I'd just drop the rear suspension and drill out all the fasteners and install new bracket with my air riveter.
Or go to another good sled and make a template so I know exactly where that top hole is supposed to be and weld it shut and redrill.
Use the same template for both sides, just flip it over and the holes should be in the same place.
Either method would take about the same time.
What do the brackets and fasteners cost?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
That's what I'll do weld er up and redrill!I'd just drop the rear suspension and drill out all the fasteners and install new bracket with my air riveter.
I don't have a air riveted and rather not remove the bracket if I don't need to
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
That’s exactly what i did to fix mine! Twice...
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
When you move from the top hole to the bottom hole , what does that affect ?View attachment 154334 View attachment 154335
Just raises seat height ?
And approach angle ?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Only difference I noticed was very heave sterringWhen you move from the top hole to the bottom hole , what does that affect ?
- 6K
- 8K
