SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Mine was barely visible in sight glass. Filled it to the top. Plan on changing it with 1st oil change anyways. I have owned a lot of Cats and the best thing you can do is regular maintenance and check chassis after every 2 or 3 rides to make sure nothing comes loose and the sleds will rarely leave you stranded.
ritchie
- Nov 3, 2014
- Seven Sisters Falls, Mb
- 2017 Sidewinder Ltx Le
I added 8 0z. of 50/50
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Yep, mine was low also, none visible in expansion/overflow tank just remnants in bottom which showed the yellow/green coolant color!
Checked all after first ride and found nothing more except one of the hood screw clips was not fastened, and I see why that one is really tight, it takes 2 hands to secure.
nadekeys
- Oct 20, 2009
- Green Bay, WI
- 2017 Sidewinder LTX LE
2009 Apex LTX GT
2008 Nytro MTX Turbo
Mine was low also but that's fine as I always like to add a little Royal Purple Purple Ice super coolant to my machines' coolant systems, seems to help them run cooler. This is what I topped mine off with.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
So I had to add coolant after first couple rides but coolant level was good for 3000kms. Just checking out my sled which hasn't moved for 3 weeks and noticed my overflow bottle was nearly empty. Checked for signs of leaks and under the sled but nothing visible. Topped it up to the cold mark and ran the sled up to 60c. Seems okay. Anybody else seen this?
Pstn head
Yes I'v added 1-litre in total a few hundred mls at a time a few times and after my last ride it seemes to have stabilized.So I had to add coolant after first couple rides but coolant level was good for 3000kms. Just checking out my sled which hasn't moved for 3 weeks and noticed my overflow bottle was nearly empty. Checked for signs of leaks and under the sled but nothing visible. Topped it up to the cold mark and ran the sled up to 60c. Seems okay. Anybody else seen this?
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
X2
saskattakman
check all your coolant clamps mine were all loose and had a leak by thermostat
Sidewinder Bob
- Nov 20, 2016
- Remsen, NY
- (2) 2017 Yamaha Sidewinder Ltx le
The same here.check all your coolant clamps mine were all loose and had a leak by thermostat
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
Me too. Not a major leak, but clamp needed tightening. Thanks to jonlafon for noticing it and addressing.check all your coolant clamps mine were all loose and had a leak by thermostat
john10toe
I added about 8 oz of coolant over the winter and couldn't figure out where it was going. Finally found leak in the metal coolant tank located on right side just forward and above chaincase. It appears to be leaking from between the mating surfaces as all screws and hose clamps are tight. I haven't taken it apart yet as the seal is on back order....
saskattakman
same place as mine was leaking had to tighten the crap out of the little clamp on the front of housing looked just like yours
DMCTurbo
- Nov 12, 2005
I had to add coolant at the end of the year, couldn't find a leak and never noticed any coolant on the ground after sitting in the garage. Figured I'd check all connections and surely 90% of them I was able to get a full turn. The ones in the pics which are hidden behind the clutches were in the 90%. My thermostat housing wasn't tight either. Hopefully that explains the missing coolant.
DMCTurbo
- Nov 12, 2005
