pay2play
No more debate, I picked up my back country track at Novi yesterday. It was a good show, fun spending it with my 10 year old. Tore into the chain case when I got home. The tech how to from Ulmer in FAQ was very helpful and will be as I continue with reassembly. I took the skid out today along with the drivers and put it back in with my new track. So far so good. I need to find a 20 tooth top gear before continuing. Also need the service bulletin update for the star suspension kit while the skid is out. Thank you for all the input, you all helped me feel better about the decision!
newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
- 2016 Polaris Switchback 800 Pro S
Ulmer should have a 20 tooth for you.
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
are the guys using the BC track for 99% trail riding changing gearing? any improvment downgearing? I know this engine has all the torque to pull the track so wondering if gearing to 20t top is worth it. Any reduced mpgs? i ride 99% trail
newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
You would probably be alright with changing to 20 tooth sprocket but it won't hurt. The nytro 1.75 comes with 20 tooth gearing as well.
I thought about leaving the stock gearing but you got it apart anyway. I never noticed any difference with mpg on mine. I also do alot of trail riding and I love the track.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Don't want to hijack this thread but anyone have an opinion on cutting down and notching a 2" to a 1.60-1.75 lug. I've seen the vids. I'm more curious of rigidity and or tearing off lugs. I was told they're a much softer compound.
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
i have thought the same thing. i woudl think the track would be much tougher than its 2.0" state. thicker lugs tend to take a beating better. i posted somewere in the last page or so a video of notching the track which is prob what i will do if i can find a 2" to cut down or notch a BC.
canoehead
- Jan 14, 2011
- NE, Alberta
I have found a few brand new 2.00" and 2.5"take offs here in central Alberta. $400.00 doesn't sound too bad after shopping and looking at prices ranging from $828.00 - $1095.00 for a new BC.
radianguy
- Jan 1, 2007
Looking for some info on the back country vs the back country x, anyone know the difference? I know the "x" is 2ply, does one wear better than the other?
jimbur
- Aug 16, 2013
- Bernville Pa
- 09 NYTRO XTX
14 NYTRO XTX
08 NYTRO RTX
07 PHAZER
- Pa.
I think the backcountry is 2.52 pitch and the backcountry x is 2.86 pitch
radianguy
- Jan 1, 2007
You can get x in 2.52 also
Maybe I should have said 9206r vs 9143c
Snowman871
- Feb 9, 2010
- Woodville, WI
- 2024 Polaris Assault 850
I've got the regular Backcountry, still lools really good after 6,000 hard miles!
m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
Yes,
1.75" fantastic for off trail or if you just want to hook up on the trail. Caused huge understeer on my XTX. Have since went to 1.5" with much better results on trail
Lman69
Guest
- Nov 5, 2013
Had a 1.75 with a 19 tooth small gear and was great on trails, however track has 6500+KMs on it and was breaking down. Didn't run DuPonts and was replacing sliders yearly.
Just installed a 2" Challenger for mountain riding, with Duponts and let's see what happens.
I replaced my ripsaw2 with the Backcountryx2 at 200 miles. Now at 700 miles I have no regrets. The sled hooks up and takes off great in good snow conditions. I also don't run studs so I have ski mounted scratchers and have no over heating issue at all.
Snowman871
- Feb 9, 2010
- Woodville, WI
I run DuPont slides, a wheel kit, and I make sure to have snow on my slides! The setup has been treating me well for several seasons!
