Winderallday!
- Dec 4, 2007
- SW, Ontario
- 2018 Sidewinder DX
I'm kinda in same boat, sled quit while riding, turns over, won't fire. Which one of these relays is the one that needs changed? I am not hearing click and fuel pump definitely not running.
Usually second one in from outside of sled in the row of relays, to be sure, find the one with the following wire colors running to it:
red/green
red/blue
red/white
blue/red
trailanimal
On my 2013 it is the outside one is fuel system, then 5 prong black with white writing is lighting system, then third one in is main system, 4th one inside one is reverse beeper and carb and grip heat. I believe you need to see 3 red wires for the fuel relay.
Winderallday!
- Dec 4, 2007
- SW, Ontario
The wires as I recall have dual colors on them, one is predominant, the other less so.
3 x red/xxx combinations and one blue/red combo.
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
just buy the 3 red relays for the ones that are the same, done. they're only $15 or $20 each
- 11K
