apex er be able to adjust the ohin
1yamadog
Sherrill NY
I'm going to buy another new sled but have alot of blue items at the house know. So I thought I could buy a apex er and install the ohlin and the fox air shocks but wanted to make sure you would be able to adjust the ohlin from the handlebars like the apex gt. Can anyone give me a answer on this thanks
1yamadog - I talked to my dealer with the same questions, and yes, if the shock package is purchased later, you will be able to have the adjustability on the handlebars, cause the wiring is there already. The only thing is the hole will be there for the RA adjuster, but could possibly be covered with the support brackets (for the tunnel), from a GT? Think about it. I will be getting the blue ER also, but you might want to keep the RA, due to it seems like it has more adjustability than the ohlins.
It would more than likely cost you more to buy it after the fact, than to buy it from Yamaha. Only about a $1,000 dollar difference between the two GT/ER in cdn funds.
