Got a chance to buy an EFI Apex gauge. Is this a plug and play for the Nytro like the Vector gauge is? I know I need to run a wire for the clock, and that the RPM's go to 13,000 on the Apex gauge. But will everything else work seeing that it is from a 4 Cylinder and not a 3. I researched but found no clear answer. Thanks!
natedawgedog
- Feb 5, 2011
- DLG, Ak
- something from 2019!
No its not the same. Don't know where the old thread is but it reads wrong.
OK Thanks. I thought I read that somewhere too thats why I asked. now I know.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
It's set up for a 4 cylinder. A Vector gage which is almost identical will work.
Thanks canoehead, I knew that but just came across an Apex one for a good deal
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
The apex gives off a different Electrical pulse then the nytro, vectors. And It needs to come from a fuel injection sled too.
Beenba
- Feb 16, 2011
- 2009 Nytro XTX
09+ vector gauge will work im pretty sure, as long as its injected.
u need to make up a custom bracket to mount it on nytro.
add 1 wire under the brown pin in the conecter, and feed it +12v for the clock to stay on.
If you serch my posts, I have a bunch showing pics of my bracket etc.
one of my best mods done to the sled
Snakebit
Best mod evah...
Beenba
- Feb 16, 2011
- 2009 Nytro XTX
I can play too
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
Your losing that race.....Snakebit said:Best mod evah...
