apex not running
legend
New Lowell, ON
Just took my buddy's apex out of the trailer, charged up battery, oil change and it will not start. Code 22 comes up on dash and no sound of fuel pump coming on. Changed plugs as well, 06 Apex. Any pointers would be apprecitated.
Thanks chris
code 22 sounds like you forgot to hook up the iat sensor in the air cleaner, as for the no-start, check the ground blocks that are in the wiring harness runnig down the delta box on the clutch side also check for corrosion on the wire running to the fuel pump relay i think its a red wire with a brown tracer.
check the fuse in the starter relay i have had two seperate no-starts on my apex one was a 6 inch chunk of red wire that turned green and into powder and on the other occasion it was dirty grounds not turning on the fuel pump and engine starter
Code 22 says that tha IAT is disconnected but it will still start and run.
Check the fuel pump relay and fuse.
The relay is on the left foot well turn the key and feel if its clicking. It should be the 2nd or 3rd one so I just get my ear down close and if you touch it you can feel it.
If that is working check the fuse for the Fuel pump which is under the airbox next to the battery in that little group of contacts directly off the battery that the jump cables come off of. It will be a 10am fuse see if its blown.
Good luck
07 Attack not starting
Wrote in a couple of weeks ago with a sled that would'nt start. Checked fuel pump fuse and it was burnt, changed fuse turned on key and burnt another fuse. Now I took seat off to check fuel pump and there was the problem, a mouse had eaten both wires off rite at the connector and chewed up the foam gasket between the pump and seat. New wire lead was only $14.00 and foam gasket was $35.00. I think I'll start putting moth balls or something in the trailer.
Re: 07 Attack not starting
I use moth balls and Bounce sheets, moth balls all around the sled and the bounce sheets under the hood, works good for me.
x2 on the moth balls put them all around sled and trailer and I tape up my exhaust pipes. Little f**kers
