Apex rear R/A adjustment/spring
wkeggenhoff
Age
60
Ajax,Onatrio, Canada
Canada
2006 Yamaha Apex RTX
I have a 2006 Apex with mono. Rode last year with R/A adjustment at Min setting all the time. Is there a way to tell if the rear spring has been swapped for a heavier one(Big boy0?. IE coil diameter,colour, free length,etc
Would like a couch like ride with setting in the middle of adjustmenst so that I cold stiffen or soften depending on trail conditions.
Would a revaleve fix this problem ?
i know the spring length are the same (i changed mine and it was the same), it's the dia of the coil should be bigger the heavier spring you go
the only way is to see if the part number is still on the spring depending on the condition of it, if it's on there than you can find out if it's stock or not, or you can go out and buy a spring according to your weight,
