grooter
- Feb 23, 2007
what is everyone running for a top gear on there apexs
LJ 452
For my 06' I was running a 22. many others are running a 23. Keep in mind I also had a 40T bottom gear. If you go 22 you'll want a shorter chain unless you also use a 40T bottom. I'm not huge into top end, for me it was corner to corner and the 22/40 was arm ripping, that is if it hooked. Top end, I still saw 112 on the speedo but before with stock I did see 128 so I guess I did loose some.
Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
This year I have 23/40 setup. No snow yet to try it but I can't wait. Stock was 24/38.
MountainMax
- Nov 21, 2004
- Churchill Falls, Labrador
- 2009 Yamaha Apex
mine came with a 20 top gear new, but they put a 22 top gear as part of a sea level kit (also clutching changes), I was curious if i can go up to a 23 with the same chain?
- 14K
