jeff catte
- May 31, 2020
- Saskatchewan
- 2015 viper xtx le, 2017 sidewinder mtx
Hey everyone. I have a 2017 sidewinder mtx and just installed the dmc top gear and found there is some side to side play and back a forth. The sled has 600 miles on it and this was purely preventative. Have you guys found there's a but of play with the gears you've installed. The shaft looks good and there isn't much wear on the old gear. I appreciate any insight
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Be sure you don't have one of the bad gears.... see this thread: https://ty4stroke.com/threads/2023-top-gear-is-powdered-metal-junk.166009/
jeff catte
- May 31, 2020
- Saskatchewan
Mines a good one, I made sure before I installed it.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
DMC specs .020-.050 thousands of play. This allows sprockets to align and run true.
jeff catte
- May 31, 2020
- Saskatchewan
jeff catte
- May 31, 2020
- Saskatchewan
jeff catte
- May 31, 2020
- Saskatchewan
Perfect. Would you mind taking a look at the video and tell me what you think?DMC specs .020-.050 thousands of play. This allows sprockets to align and run true.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
You could put a shim behind that gear to push it out towards the snap ring if it concerns you.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
sounds more like the bearing behind than the gear itself.
jeff catte
- May 31, 2020
- Saskatchewan
Maybe the videos not that good. I was trying to show how much the gear can "wiggle" on the shaft. It's hard to see in the video so it must not be that bad.sounds more like the bearing behind than the gear itself.
RDOG907
- Jan 5, 2023
- Alaska
- 2017 Yamaha Sidewinder MTX 162
Wiggle room should be about the width of one snap ring according to the other threads.
jeff catte
- May 31, 2020
- Saskatchewan
Ok thank you. I threw it back together. I'll check for wear in the spring
- 19K
