excallibur101
Its a pretty big job but I have done several and you do not need to pull the motor to do them... if you have to get one new its crazy expensive but there are guys that sell them for half the cost. Check the classifieds.
excallibur101
Whats the approximate time frame to do this job from start to finish without beer breaks.Its a pretty big job but I have done several and you do not need to pull the motor to do them... if you have to get one new its crazy expensive but there are guys that sell them for half the cost. Check the classifieds.
I can do one in about 8 hours.... maybe even less if I am on a roll.Whats the approximate time frame to do this job from start to finish without beer breaks.
excallibur101
Hopefully on my part the insurance company will be generous,otherwise I am going to be up shits creek without a paddle for some time as the nightmare is about to begin for me. Thanks for the information.Its a pretty big job but I have done several and you do not need to pull the motor to do them... if you have to get one new its crazy expensive but there are guys that sell them for half the cost. Check the classifieds.
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
depending on how bad and where the damage is, you may be able to repair it with the bulkhead repair kit that barn-of-parts (hibshman25) makes, there are you tube videos showing an install of some of them if you look them up. Send him a PM or call him and he could help you.
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
What about all the EPS electronics in the nose cone area? Isn't that what all the additional items are up there in the new models? I suppose you won't know if it's bad until you get everything else in place.
Tough one bud, sorry for the loss.
excallibur101
I have not attempted as of yet to dissassemble machine to dig into it any further to see for further damage,although one of the modules did sustain damage as well as cracked bulkhead,waiting on word from insurance adjuster on what my next steps will be.This was its first trip out since I bought it as a new leftover in October and the season just begun and now this happens.On a brighter note at least I am ok .The sled an be fixed or replaced.What about all the EPS electronics in the nose cone area? Isn't that what all the additional items are up there in the new models? I suppose you won't know if it's bad until you get everything else in place.
Thats a bummer!
Did it on mine couple years ago but its an 06 that has 2 halfs on bulkhead,a left and a right.its not too bad but i wouldnt want to do another one! revits you have to drill out and replace ,steering moved up front etc etc.took me 2.5 days to do cause it was my first one. look it over real good ,your going to probably need a-arms on the right,new oilite bushings on a-arms ,check sway bar,tie rods and ends,front shock maybe bent,bottom of sled banged up also,bent bolts ,oil tank took a whack too probably..mine did .
You DO NOT have to pull engine ! and i found all my parts off Craigslist cheap! put some $$ in my pocket too! i will always have ins.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Have the bulkhead welded and then install bulkhead saver.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
had a buddy do this to his 11 XTX last year it costed 7500 to fix they valued the sled at 11000 so they fixed it took for ever because of waiting on some parts from yamaha back order.
Joey P
- Dec 12, 2014
- minocqua
- APEX XTX SR Viper XTX
did you drive it after that did the eps work still
excallibur101
I have not began to disassemble the front end as of yet anyhow as I am still waiting word from insurance company on what my next steps will be or what to do.Are there any other critical area I should be aware of to check for damage before claims process begins ?I am positive bulkhead is cracked in few places and will need replacement if they allow to go that route or just total sled.What is a estimate cost of a new bulkhead for this sled from Yamaha ????Anyone know ???I have not attempted as of yet to dissassemble machine to dig into it any further to see for further damage,although one of the modules did sustain damage as well as cracked bulkhead,waiting on word from insurance adjuster on what my next steps will be.This was its first trip out since I bought it as a new leftover in October and the season just begun and now this happens.On a brighter note at least I am ok .The sled an be fixed or replaced.
Sidewinder
- Mar 19, 2005
- Ontario Canada
- www.streettechracing.com
- 2017 Yamaha Sidewinder LTX LE
- Waterloo
I just today hit something and ripped the lower right control arm out of where it bolts in.
Any saving the sled?.
I'm going to the shop tomorrow and tear it apart.
Contact Travis. He has a kit to repair damaged bulkheads.
http://www.barnofparts.com/Bulkhead-Repair-Kits.html
