biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
So have any of you riveted some belting or other rubber to your existing snow flap to extend it? I saw one photo and I should have saved it.
My buddys bitch constantly about the amount of snow/ice that my XTX throws out the back. And now with the larger lug track, it's even worse.
I find that the XTX's bumper is much higher than the GT I once owned. And the stock flap just does not do a very good job. Anyone else experiencing this? Should I just bend the flap down, or extend it with rubber belting. I really don't want it to look half-assed either.
I would leave it as is.. this is how we keep people off our #*$&@ when trail riding... if you ride that close you will regret it...LOL
you could try the apex mtx flap as those are usually longer.
i know i am never close to sapplingkiller as he runs a bravo flap on his sled once he rips off the stocker on something.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Guys will bitch about everything. That's why I love to ride with my wife she never says a word and is always smiling.
musselman
- Apr 17, 2009
- Fenelon Falls, Ontario
- 2019 Ren XRS 900T, 2010 Nytro RTX
Maybe a viper flap would work, they are a bit longer. I know a few people have put them on nytros. I think the xtx's are much worse than the other apex's, the flap is stuck straight out almost.
snoseeker
- Oct 9, 2005
- FARMINGTON MN
- just up dated to a 2017 sidewinder , 2011 xtx apex, 07 attack, 98 700 delux, 97 600 sx
- minnesota
just leave it they can back off like MRSLED SAID
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
Yes, my friend's have the same "complaint" as well. The flap seems to set much higher compared to an SE. Was wondering if the flap flattens outward when riding and if securing it from doing that would help.
snoseeker
- Oct 9, 2005
- FARMINGTON MN
- minnesota
that is just the way the flap is on the xtx
snoseeker
- Oct 9, 2005
- FARMINGTON MN
- minnesota
if you must try this
provendesignproducts.com
You guys crack me up! Gotta agree though if they are complaining then they are too close or to slow to pass. Screw them! I have been there swearing and admit doing something stupid to pass quickly one time..... long story.
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
- 2018 Sidewinder LTX LE, blue
2011 Apex 128, Ulmer Airbox and clutch kit, PCV, HID
1980 Exciter 300
Been riding behind my brother's Apex xtx for 7 years now. The roost definitely got bigger when he went to the 1.75BC track. I don't mind it. It a good way to keep off his flap. Every now and then he'll throw a huge piece of ice. I figure it keeps me alert...
Smokum
- Jan 31, 2011
- Prairie du Sac WI
- 2011 Apex XTX, 2003 RX-1 MTN
I added on to mine. Used some short stainless bolts and fender washers to attach a 6" chunk of a rubber tailgate liner to the bottom of the stock flap. I did it as my back was getting covered with snow and it also helps with lubrication and cooling as it keeps more snow in the tunnel. It doesn't look too bad. I would like to find an actual longer flap though if someone knows of one.
20/80
- Mar 25, 2010
- Nova Scotia
- 2016 APEX LE XTX
The snow flaps that the pro racers use on the snow racing circuit would be what you are looking for, but not so good when backing up though, dealers should be able to get them, or aftermarket.So have any of you riveted some belting or other rubber to your existing snow flap to extend it? I saw one photo and I should have saved it.
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
I do have a spare Viper flap that was purchased for my daughters LTX. But we never installed it. The Apex's bumper is different enough, that it would be difficult to attach that flap without other mods. It's just not the same.
Thanks for the tips guys. All good suggestions. I may extend it with belting before our Michigan trip. This past weekend, I kept having a scratcher drop. And after 160+ miles, I had over 25lbs of ice built up under my tunnel and flap. Those boys really bitched when one of those chunks would drop. WOW.
At this point, it's not my problem. And if they make it my problem, I don't have issues bringing up the rear.
Darren Betker
- Jan 16, 2017
- Dryden
- apex gt
Not for yamahas tho
