ExTrEeMF7
if i remeber right we did all this last year with me and terry on our asphalt sleds .. now were is that post ???? :itchy:
1xr,
I was running stock warrior gearing (w/Reverse) 23/38.
--Buster696--
--Buster696--
Magic, Yep... it does...
Hey guys I forgot to mention this in my orginial post... (This was the Good of the night...)
I got 3rd place/Semi's on Wednesday night. Had a 'buy' or 'by' run, (Good time to do a test-n-tune run) :lol: so I went to the semi's. Then mr. red light showed up...
--Buster696--
--Buster696--
- Apr 14, 2003
- Hessel, Michigan
Buster - Joel would like you to call them at Wahl. 218-782-2295 He said your front torque arm is sucked in too much, he thinks. I hate that red eye myself.
everyone - will be trying Mr Sled's setup tonight, and he said it should shift out more. If that is the case, I could drop down a little on gearing, and still keep my top end charge. 22/38 worked good, but ran out of gear with the stock clutches. These are machined, to ramp faster, and use the most of the clutches. Hope for clear skies, cause they are predicting rain all weekend.
Nos,
Thanks for the info...
That was going to be my next move with the skid.
I'll give him a call to discuss plus a couple more items related to that skid.
Thanks again,
--Buster696--
Thanks again,
--Buster696--
Troops...I found out the hard way you gotta gear rx-1,s tall. Gearing em down slows you down all the way thru. Been der dun dat not doing it again!!!
Turk: You talking stockers or Turbo sleds. My turbo had zero problem pulling 145 plus on the speedo with 22/40.
ExTrEeMF7
Buckeye
- Lakes Region, NH
My times and mph were better with taller gearing. The turbo had the power to pull the gears. Especially the mph!
My stocker has always liked the taller gearing as well. More power should mean more gear yet...BBY
therxwon
Hears my set up and what happened. Front mount 10lbs Wahl with 121x10 track.23/38 10tooth drivers using 8bu 1st run track broke loose
10.848
125.06mph
Best of the nite
60'...1.654
330...4.204
1/8...6.377
mph.110.85
1000..8.325
1/4...10.032
mph...130.22
It will be in the 9s next time i hope.
10.848
125.06mph
Best of the nite
60'...1.654
330...4.204
1/8...6.377
mph.110.85
1000..8.325
1/4...10.032
mph...130.22
ExTrEeMF7
i ran 8bu also in my set last year on the tar and i got my best speed and 60 foot and top end with 8bu on the TAR ....
- Apr 14, 2003
- Hessel, Michigan
Hey everybody - Friday 5/7/04 & Sat. 5/8/04
Friday - 52 degrees with 22% humidity (total 5 runs)
1st run - without NOS, Sleds cut clutches and setup
1.516 60ft. - 6.895 1/8 mile @ 97.615mph - 11.128 1/4 mile @ 112.557mph (rpms were 9,900 and went to 10,100. Clutch temps: primary 107, and secondary 124)
2nd run - with NOS 48 horse spray after the 60 ft. mark, no clutch changes
1.534 60ft. - 6.382 1/8 mile @ 108.059mph - 10.184 1/4 mile @ 125.006mph (rpms started at 10,000 and jumped to 10,400. clutch temps: 114 , and 129. WOW, What a ride!!!
3rd run - with NOS, tried to use just after the start line=no luck.
1.563 60ft. - 6.781 1/8 mile @ 103.369mph - 10.677 1/4 mile @ 123.264mph. (spun big time after the 60ft. mark. If I had a side mower, I could have trimmed the side of lane 2 for them.)
4th run - with NOS
1.507 60ft. - 6.692 1/8 mile @ 105.024mph - 10.580 1/4 mile @ 123.247mph. (spun again)
5th run - with NOS
1.514 60ft. - 6.526 1/8 mile @ 105.502mph - 10.412 1/4 mile @ 122.622mph. (spun again)
Saturday - May 8th Summit Super Series (59 Degrees with 90% humidity)
1st run - Without NOS, and a brand new Yami belt.
1.508 60ft. - 6.995 1/8 mile @ 94.701mph - 11.288 1/4 mile @ 111.635mph.
2nd run - Without NOS
1.496 60ft. - 6.895 1/8 mile @ 95.583mph - 11.156 1/4 mile @ 111.242mph.
Then got cancelled due to Thunderboomers.
4th run - with NOS
5th run - with NOS
Terry that new belt once broke in should have pulled some good numbers...
