Attak/Apex Clutch Setup (Barn of Parts Spring)
zr8000
This is my first year with a 2007 Attak. I have always played with my setups but with this sled, I did not want to mess with tuning. I found that stock setup, however, was terrible for running below 15mph and I could smell belt burning. The only thing I ended up purchasing was the barn of parts spring that provides softer engagement. This spring is slightly shorter than the stock one but after comparing (I swapped back and forth several times) I found everything else to be the same. Also compared the stock setup with this barn of parts spring to sled with a popular clutch kit and there was only a very minor difference.
If you want to improve the 'friendliness' of the clutching at low speeds but don't want to spend over $30 or tune a lot, try this spring!
