SpartaSXr
- Apr 14, 2004
- Western Michigan
- 69 SL351 - 70 SS396 - 98 V-Max 600 XT - 99 Phazer - 06 Attak
Now that Pioneer is closed is there another company to get the kit from to eleviate the slider wear on my Attak ? Or are oversize wheels the only way to remedy the problem ?
Excell makes oversize wheel kits.
yama_rider
- Sep 15, 2014
- New Brunswick
- 2009 RS Venture
I have an Attak and don't have any slide wear problems at all with stock wheels. The Duponts will last forever as long as you run ice scratchers in marginal conditions. Plus the ice scratchers will keep the sled from overheating on warmer days too.
HABS 1
- Oct 22, 2015
- corunna,ontario
- 2006 apex gt,136 Hartman ext,dalton clutched,full excel exhaust,yamiheaters,cna pro ex white skis,hid lights,mtx riser,1.5 intense track,etc,etc!---2021 sidewinder xtx se
check out marginal snow wheel kit thread a few down from this post, i put a measurment of my dupont slides after 3000 plus miles, put duponts on and forget about it!!
As Mr Sled mentioned http://www.excellmotorsports.com/xwheels.htm.
or this works well too http://www.ty4stroke.com/threads/idler-wheels-2-bolt-mounts-mono-skid-fixes-pics.78847/
The small wheel kit at the front bend well help as well
Hoxtongue
I have an 06 RTX and it eats slides every 300 miles or less. I installed scratchers and it helped a little, then installed Dupont sliders and it also helped a little, but still isn't great. I am getting low near the rear of the slider, including in front at the bend. I just ordered the marginal snow wheel kit, I am hoping this gives me a little extra mileage, but it seems to be hit and miss. Some have issues and some don't.
HABS 1
- Oct 22, 2015
- corunna,ontario
keep track as loose as possible witout skipping,i have extro drivers and 1.5 inches of track sag
bigdog_mike
Yeah track sag is critical to hy-fax life, also you can run polaris style 5.35" wheels as the have the same bearing ID as Yamaha and this will also help to minimize hy-fax wear. Kimpex wheels only run $28 with replaceable bearing and my Apex gets at least 2 seasons 1000 miles plus per season of use. I used the bumper block near the rear of the rails as a measurement point as the block have a metal bracket that you can measure the sag from for a pretty accurate and repeatable measurement.
rangermike14
- Feb 19, 2015
- Byron Center, MI
- 2006 Apex
1998 SRX 700
You can actually still call Pioneer Motorsport and order the parts that Bruce use to sell from Pioneer Performance. Pioneer Motorsport has all of the left over stock still.
