craigwsrx
- Feb 19, 2007
- Fenton Mi.
- 2017 Sidewinder 27,000 miles
2009 Nytro xtx 31,000 miles
2006 Attak 26,500 miles
2003 RX1 13,500 miles
2000 Mountain Max 14,000 miles
1998 SRX Mountain 17,000 miles
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
I was riding and my sled suddenly quit running like you turned off key, no warning no studder. The dash stayed lit. Fuel pump does not run when you turn key on. It will run if you jump it. I tried computer out of another Attak, same problem, I tried relays, same problem. I have spark, if I shoot gas in throttle bodies it fires. If I jump fuel pump it will not fire up. I removed fuel line at rail and it will pump fuel, not sure of fuel pressure. Sled has 12,000 miles. Any suggestions?
LJ 452
Injectors?
Maybe a bad TPS. I'm assuming if the comp. doesn't see a thottle pos. it may not fire the injectors. But I would also think that this would give you a code on the display. So I guess I'm back to injectors.
craigwsrx
- Feb 19, 2007
- Fenton Mi.
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
I do not get a code. I am waiting for a backordered manual from Yamaha so I can trouble shoot properly.
blue er
check for injector pulse.
Is it possible a mouse has gotten into the wiring check around the bottom of the secondary (i found a little present there myself)
also my owners manual has wiring diagrams use thes to troubleshoot your fuel problem if possible.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
check for frayed wire...seems to me I remember seeing some frayed and grounding intermittently against the chassis
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
craigwsrx said:I was riding and my sled suddenly quit running like you turned off key, no warning no studder. The dash stayed lit. Fuel pump does not run when you turn key on. It will run if you jump it. I tried computer out of another Attak, same problem, I tried relays, same problem. I have spark, if I shoot gas in throttle bodies it fires. If I jump fuel pump it will not fire up. I removed fuel line at rail and it will pump fuel, not sure of fuel pressure. Sled has 12,000 miles. Any suggestions?
Alright, you have no power at the fuel pump. So find the relay....I can check the wire colors for the FP relay in the morning...my manual is in the truck. Some say the 2nd relay is it, others says it's the 3rd relay!!
Once you are sure you have the CORRECT relay, check for power TO it. I can also lead you to the ECU.
Obviously if you swapped ECU's, you have a bad relay or cut wire.
craigwsrx
- Feb 19, 2007
- Fenton Mi.
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
It ended up being the 10 amp fuse under air box by battery that runs injectors. Very bad spot for a fuse to change or check in a snowstorm in the UP. Thankyou everyone for input.
87gtNOS
- Nov 30, 2005
- Toronto
Glad you found the problem.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
now you need to ask yourself why that fuse blew...
87gtNOS
- Nov 30, 2005
- Toronto
Is there a smiley for a new can of worms??!!!!!!sj said:now you need to ask yourself why that fuse blew...
craigwsrx
- Feb 19, 2007
- Fenton Mi.
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
There was a little corosion on blades of fuse and lots of miles on sled. I just got finished riding sled and it seemed fine.
