chaleurphantom
- Oct 5, 2009
- Northern New Brunswick, Canada
- 2018 SIDEWINDER LTX-LE 50th Anniversary
2016 VIPER XTX LE - WHITE,
2009 VENTURE GT,
1995 POLARIS INDY 500,
1984 SKI-DOO CITATION 3500
After years of trying different apparatus to move these heavy sleds around the garage I have finally found the perfect solution. Eazymove long track dolly. Amazingly simple and effective. Its so easy on your back it is ridiculous. 700lbs feels like 20lbs. I watched the video and was skeptical but I highly recommend it.
I have no affiliation with the product but I was looking for something like this for awhile and I am sure every other sledder has as well.
- You can use it from either side of the sled.
- It comes apart easy to hang on a wall to minimize space
- Allows sled to turn on its own axis
- Easy to elevate track onto a stand to adjust, tension, inspect etc...
- Makes it easy to run track to adjust drive belt deflection in Secondary clutch
Wingwong
- Mar 20, 2018
Very cool and innovative
34pontiac
Had one for years
Works good.
You can get the larger wheels for it so you can push it across gravel.
Works good.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
This will hoist up a turbo as well?... How big of wheels can you get?
chaleurphantom
- Oct 5, 2009
2009 VENTURE GT,
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Bt04f250
- Mar 6, 2017
- IL
- 2018 sidewinder xtx 137 high Vis ordered 2012 Polaris rush pro r Le
I have one of those. Works great. My sidewinder sits on the dolly majority of the time. When I use the off road wheels I just make sure they have a lot air in them. The standard hard wheels are about 3.5” diameter. I would have to go check but I believe the off road pneumatic wheels are about 10” tall and about 2.5 inch wide.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Kind of sucks you have to take a wheel off one side to slide under the sled.... 10" wheels
Bt04f250
- Mar 6, 2017
- IL
It only takes a couple seconds to remove/install the large wheels so it has never bothered me. I also don’t use the large wheels very often.Kind of sucks you have to take a wheel off one side to slide under the sled.... 10" wheels
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Who sells them?
chaleurphantom
- Oct 5, 2009
2009 VENTURE GT,
You can buy directly from company. Google EAZYMOVEWho sells them?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Who sells them?
Seen this style around for many yrs, but this one does look rather nice overall. Just not something I really need but very slick, even for just turning around ect.
Dan
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
I think with the big wheels and a ridiculous amount of air pressure you could do a lot with it... May give it a try if i could ever stop spending money trying to get my Winder running right...lol
hmmrdwn
- Jan 7, 2018
- 2018 Yamaha Sidewinder LTX-SE
i bought one last year. love it for the sidewinder.
Wonder if my #*$&@ look as good as hers when I move my sled?Seen this style around for many yrs, but this one does look rather nice overall. Just not something I really need but very slick, even for just turning around ect.
Dan
