Backsaver Garage Dolly
Northern New Brunswick, Canada
Canada
2018 SIDEWINDER LTX-LE 50th Anniversary
2016 VIPER XTX LE - WHITE,
2009 VENTURE GT,
1995 POLARIS INDY 500,
1984 SKI-DOO CITATION 3500
After years of trying different apparatus to move these heavy sleds around the garage I have finally found the perfect solution. Eazymove long track dolly. Amazingly simple and effective. Its so easy on your back it is ridiculous. 700lbs feels like 20lbs. I watched the video and was skeptical but I highly recommend it.
  • You can use it from either side of the sled.
  • It comes apart easy to hang on a wall to minimize space
  • Allows sled to turn on its own axis
  • Easy to elevate track onto a stand to adjust, tension, inspect etc...
  • Makes it easy to run track to adjust drive belt deflection in Secondary clutch
These are just a few things I noticed the first time using it. Very handy.
I have no affiliation with the product but I was looking for something like this for awhile and I am sure every other sledder has as well.
Very cool and innovative
Had one for years
Works good.
You can get the larger wheels for it so you can push it across gravel.
This will hoist up a turbo as well?... How big of wheels can you get?
I have one of those. Works great. My sidewinder sits on the dolly majority of the time. When I use the off road wheels I just make sure they have a lot air in them. The standard hard wheels are about 3.5” diameter. I would have to go check but I believe the off road pneumatic wheels are about 10” tall and about 2.5 inch wide.
Kind of sucks you have to take a wheel off one side to slide under the sled.... 10" wheels
It only takes a couple seconds to remove/install the large wheels so it has never bothered me. I also don’t use the large wheels very often.
Who sells them?
Seen this style around for many yrs, but this one does look rather nice overall. Just not something I really need but very slick, even for just turning around ect.
Dan
I think with the big wheels and a ridiculous amount of air pressure you could do a lot with it... May give it a try if i could ever stop spending money trying to get my Winder running right...lol
i bought one last year. love it for the sidewinder.
