Fasteddiee122
- Apr 11, 2015
- Websterville VT
- 09 yamaha nytro fx
What's the easiest way to remove old lower ball joints ??
radianguy
- Jan 1, 2007
Pretty easy, just took one out of an old arm the other night( not on sled)
Remove circlip and pound out. If arm is still on sled you'd have to disconnect it from spindle first.
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
I had my arms off doing oilite bushings so I just pressed them out with my HF press. taking them off the spindle and setting the arm on a block of wood you should be able to pound them out with a hammer and large chisel/punch.
NH_Nytro
- May 15, 2011
- Colebrook, NH
- 2008 Nytro
2007 Rs Vector
Mine came out with a small c clamp and socket, pressed back in the same way.
mnman309
Go rent a ball joint press at oriellys for free, that's what I did.
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
just grab a couple of souckets one large enough to press the ball joint into and one small enough to drive it though. Put a C clamp on there and go to town. If that don't work take the a arm off and press it out. Piece of pipe will work as well in place of a socket.
Fasteddiee122
- Apr 11, 2015
- Websterville VT
Thanks guys I have them a good wap and they piped right out !
- 10K
