![](/styles/vip.gif)
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Been working at these sway bars and soon have some prototype samples ready to ship. For those wanting stiffer I have some with a thicker mid section and I also made some out of different materials. Hoping to get these out at discounted prices for testing/feedback. Product like this really needs trail time to get tested. If they end up breaking prematurely and don't work out I will most definitely take care of you.
One nice feature of my bars is they eliminate the panel rub from sway bar links rubbing the plastic. Its a rather trivial thing, but always found it annoying when brand new sled gets rub marks on it from sway bar. The BOP bar has adequate clearances and the shoulders on bar prevent the bar from being able to shift left and right in the chassis.
Originally I had hoped to have the bar being adjustable with 3 hole settings but once I had the bars in hand I realized the geometry would not hold out for this to work. The discounted prototypes will have 3 mounting holes but 2 of them can not be utilized. Production run will only 1 hole.
Bar utilizes the stock links and we use a reducer bushing in the top eylet for an M6 mounting bolts into the bar. Some are sure to question the smaller bolts but Skidoo sway bar links mount with M6 bolts. I will likely experiment with some different m6 bolts grades with hopes of getting the bolts to fail before the bar. If the bolt functions as a shear pin then its simple bolt replacement vs new sway bar.
New oem bars list for around $125. I'm thinking I will sell prototypes for $50 to get some out for testing and feedback. If interested in one reach out to me.
@hibshman25 If you have a slightly stiffer than stock prototype I would be down for testing one out.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Ill try one Travis. Was ill most of last fall...winter spring...lol...but not much snow anyway. Hopeful for a good winter and health this year. You know our upstate NY trails and cowpaths (broke a pioneer 13mm on the apex on a rough field) so it will get a good workout.@hibshman25 If you have a slightly stiffer than stock prototype I would be down for testing one out.
Thanks for all you do!
Oh yeah, stiffest one youve got as I run the front very soft. Works for me.
Turboflash
- Mar 18, 2019
- Southern MN
I think the stock bar is a bit too soft - too much lean in corner, especially with carbides that are aggressive.
RAMSOMAIR
Pick me Travis!
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
I would love to test out Travis.
![](/styles/TYLifeMember.gif)
![](/styles/donate.gif)
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Nice design feature that allows the use of the stock inner and outer bushing. As I mentioned elsewhere the larger cat bars require larger bushings. Not hitting the belly pan is also a nice feature.Been working at these sway bars and soon have some prototype samples ready to ship. For those wanting stiffer I have some with a thicker mid section and I also made some out of different materials. Hoping to get these out at discounted prices for testing/feedback. Product like this really needs trail time to get tested. If they end up breaking prematurely and don't work out I will most definitely take care of you.
Question? How does the alloy you used compare to stock bars?
Good work Travis !
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I had metallurgy testing done on the stock bars to see what the factory ones are. The alloy I'm using is a higher tensile strength. I've used this alloy for years on my Apex 13mm sway bars and have never had anyone report to me that they broke one. Really don't want to post specifics on the material as we all know there are some vendors just waiting to poach my next product after I do all the legwork.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Exactly. Protect your own intellectual knowledge!
Although I heard a rumor Yamatanium is quite strong!
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
Appreciate the update. A higher than stock tensile strength is all I need to know. Also, have the bolt be a shear pin rather than break the bar is a good idea.I had metallurgy testing done on the stock bars to see what the factory ones are. The alloy I'm using is a higher tensile strength. I've used this alloy for years on my Apex 13mm sway bars and have never had anyone report to me that they broke one. Really don't want to post specifics on the material as we all know there are some vendors just waiting to poach my next product after I do all the legwork.
acpantera
Have you tried installing one on an EPS winder?I had metallurgy testing done on the stock bars to see what the factory ones are. The alloy I'm using is a higher tensile strength. I've used this alloy for years on my Apex 13mm sway bars and have never had anyone report to me that they broke one. Really don't want to post specifics on the material as we all know there are some vendors just waiting to poach my next product after I do all the legwork.
How common is the stock sway bar for breaking? I have a 2017 LTX LE with 16,000km and haven’t had any sway bar issues. Are guys breaking them when smashing through beat up trails?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Typically from taking a hard hit on one ski yes. Riding nice flat groomed trails you may never break a bar in the entire life of the sled. All depends on the riding and abuse it goes thru.
It's made of steel, and when you flex steel enough it will break eventually.
acpantera
I snapped one one my Tcat last year, I don't pound on the moguls, I was just running around a tight right hander and SNAP. Machine had about 3,700 miles on it.How common is the stock sway bar for breaking? I have a 2017 LTX LE with 16,000km and haven’t had any sway bar issues. Are guys breaking them when smashing through beat up trails?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I broke one going about 20 mph down a rough ungroomed trail. One ski went into a hole and the other on top of a mogul. The extreme flex snapped mine.
- 52K
