GYTR GEARHEAD
i am still using plastic clip but a different style they are a little longer
GYTR GEARHEAD
the top clip doesnt do much on the stock plastic plate beside stopping it from rattling the one i made sit tight again the frame and i used 1/8 sticky foam sheet to prevent any rattling and to protect the paint on the frameAre you still using the push clips to hold the aluminum plate up? I noticed you got rid of the top front one....
MTX comes with a narrower front end than all other nytros. Not sure if the MTX has sway bars....
All model year XTX's have tip up rails not just 2012's.
2013's xtx's came with the same track as all other year xtx's, BUT in 2013 there was an XTX 1.75 option which came with the 1.75" backcountry track, and i think extrovert drivers (not 100% sure on the extroverts).
There were minor upgrade to models each year, stuff like improved strengthening of the subframe, handwarmers, seat material, tuner skis.
GYTR piggyback shocks were eliminated in 13'? I think it was 13....
All model years came with a 1.25" track except the xtx 1.75. They did change the shortie track to a ripsaw II i think in 2013, not sure if all shorties got this or just the rtx.
RTX came with fox floats up front. RTX SE came with fox float X (piggys)
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
And you have one more modell.
TTX 1.75" 144" with Öhlins TTX shocks all the way around. 2013 - 2014
and I forgot about two more.
M-Ride 2.25" 162" with Fox Float 2
X-Ride 2.25" 153" with Fox Float 2
both with adjustable bar riser.
![194_2014_1_org.jpg](/proxy.php?image=http%3A%2F%2Fwww.sledtrax.se%2Fsnowmobileinfo%2Fmembers%2F194_2014_1_org.jpg&hash=0bc595b7205085d2ae012936abe75275)
![195_2014_1_org.jpg](/proxy.php?image=http%3A%2F%2Fwww.sledtrax.se%2Fsnowmobileinfo%2Fmembers%2F195_2014_1_org.jpg&hash=7851c7f195ee006a29356c2141859a7c)
![192_2014_1_org.jpg](/proxy.php?image=http%3A%2F%2Fwww.sledtrax.se%2Fsnowmobileinfo%2Fmembers%2F192_2014_1_org.jpg&hash=8736bec4368b36bf7db66a3dac76748f)
[emoji12] yes forgot about those models...wish we could get them here
- 149K
