Just getting used to this '06 Attak. I had it up to Two Harbors MN last weekend for a 350 mile ride. Besides the darting, it is awesome. However, it would not start one morning, it was about 0 degrees F. The battery may be original. Started fine all day after jump start in the morning. it would spin that morning, but not fast enough to start. I might need a new battery(?), what brand is best, and, what CCA should I get? Thanks
Stock battery is fine for the machine. What type of engine oil do you have in there? 0w-30 or 0w-20 would help the motor turn turn over better when it is colder. Some people prime the system when its cold. Meaning they cycle the key on and off about three time before starting. This makes sure the fuel system is at full operating pressure.
