Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Idk....I think they should have manufactured it with a similar size body as a group #20. I'm sure your Earth X 36 is a little more robust.Why won’t it ?
Its is amazing the power in the 15 lb lighter lithium!Oh dear lord...there must be some kind of mistake! This battery couldn't start my moped?!?!
Doc Harley
- Oct 17, 2016
- Here & there
Ok, well....I'll have to give it a try. Says 3x longer life. So that's 21yrs. Haha. I'm just playin'.Its is amazing the power in the 15 lb lighter lithium!
Pulled 13.29v on DVOM
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
I bought a 100ah battery for my trolling motor. The thing weighs 19lbs, the battery it is replacing weighs 65lbs. It will also run longer, so smaller, more capacity, lighter.. win, win, win.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
not much to my 36 either. Works well though
Doc Harley
- Oct 17, 2016
- Here & there
Question....has anyone successfully tried to jump one of these batteries with a jump pack.
I hear the possibilities of other critical components can get damaged during he process.
Doc Harley
- Oct 17, 2016
- Here & there
Any questions or concerns?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Frequently Asked Questions About EarthX Lithium Batteries
This page provides the most frequently asked questions about EarthX Lithium Batteries. If you have further questions please contact our team.
There is a section on jump starting
Doc Harley
- Oct 17, 2016
- Here & there
Thanks, earthling....the answer is yes. Lots of other facts in there as well.Frequently Asked Questions About EarthX Lithium Batteries
This page provides the most frequently asked questions about EarthX Lithium Batteries. If you have further questions please contact our team.earthxbatteries.com
Turboflash
- Mar 18, 2019
- Southern MN
I have a question - where is the direct connection to fuel pump relay? See this link: https://boostkinetics.com/shop/ols/...0-998t-external-fuel-pump-harness-relay-turboAny questions or concerns?View attachment 173931
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
BRP Renegade mxz 800
Exact same for me, 8th season on a 17 Sidewinder, I keep it on charge until season starts... if I need to replace it I'll definitely go with the same battery.I'm going on season #8 with the original battery. Turned on ignition and the display showed 11.3v. It's time.
I look to you guys as I know you are battle tested, riding in the harshes environment.
Most of your days start & ride in the sub 0°F temps.
So, which battery keeps you guys going?
Thank you..... Joe
Note: looking at Earth X etz14c. Does it require a special charger?
I ride in North of Quebec City and it gets really cold... never had an issue with the oem battery.
Doc Harley
- Oct 17, 2016
- Here & there
Hmmm....good call, I don't see that either. Haha! Ill get that going and move my return line as well. I already have grommet & elbow. While on this subject is there a plug & play pump upgrade I would consider? Ya know, Christmas is just around the corner. Thanks, TurboflashI have a question - where is the direct connection to fuel pump relay? See this link: https://boostkinetics.com/shop/ols/...0-998t-external-fuel-pump-harness-relay-turbo
Oem has been so good to me. I keyed up the sled and noticed 11.3v and said to myself,"well, I guess its time" When I pulled the battery today it tested out at 12.3v. Which is better, but I knew it was time anyway.Exact same for me, 8th season on a 17 Sidewinder, I keep it on charge until season starts... if I need to replace it I'll definitely go with the same battery.
If you own a DVOM You can pull the positive wire off the battery And load test it. Need to pull the fuel pump fuse. If the battery pulls under 10.8v or so, its probably due. Especially in those temps you ride in. If you have any questions let me know.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Doc Harley
- Oct 17, 2016
- Here & there
What's up with that cover over your return line?!?!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Just a safety measure since I am using the yamaha return nipple and grommet.What's up with that cover over your return line?!?!
No issues at all but just piece of mind when running thru the trail junk...
