fourbarrel
Building a collection one sled at a time
- Sep 23, 2004
- New Brunswick
- 2019 SRX
What's everyone using for a replacement battery in their Sidewinders? Going back to the stock Yuasa one or have you found a better one? Same type of lead acid or AGM, gel cell?
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Earth X lithium
x2
x2
Shorai, but when I'm not after the lighter weight, I use YUASA
sab2022
- Feb 21, 2020
- Maine
- 2023 Sidewinder S-TX GT
You'll get as many opinions about batteries as there batteries. Suggest research. For me and my Powersports (5 batteries) Odyssey AGM. Find out when your local parts store has battery sales and buy it then. Also buy a Schumacher battery (load) tester for the sled and the cars.
Turboflash
- Mar 18, 2019
- Southern MN
There's been multiple threads here on TY about this.
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
Earth X is fantastic
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
EarthX here to 3 yr for it. Was in my viper for 2yrs
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Yuasa GYZ series.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
$69.99 Royal distributing YTX-20. I get a new one at the start of every season, never had a battery issue doing it this way.
I'd go for the YUASA for $130 and be good for at least three years.$69.99 Royal distributing YTX-20. I get a new one at the start of every season, never had a battery issue doing it this way.
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
Ive done it, and never had a yuasa last 3 years for me. I put new batteries in everything at the start of every season now. Sleds and jet skis. Honestly, these batteries will probably last just as long as a yuasa, but for the cost, it’s worth it for me to never have a battery issue while in the middle of nowhere.
Glad it has worked for you, I've just had bad results with the cheaper batteries and I used to sell them. A few years ago, I couldn't get the YUASA spec battery for a Yamaha Vstar 1100, as they weren't in stock so I opted for the cheaper replacement. The machine came back a few weeks later, all the lights were blown as the voltage was spiking up to 17 volts. Put a good battery in, problem solved.Ive done it, and never had a yuasa last 3 years for me. I put new batteries in everything at the start of every season now. Sleds and jet skis. Honestly, these batteries will probably last just as long as a yuasa, but for the cost, it’s worth it for me to never have a battery issue while in the middle of nowhere.
hellflyer
- Dec 2, 2008
My stock battery started leaking in my viper the second yr. Caught it before it made a big mess. That's why I went with EarthX
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
The Shorai didn't last that long for me. After the first year, it got weaker & weaker on cold starts.
Earth-X is amazing & weighs exactly 12 lbs less than stock, but is over $250. No problem in cold weather either.
For me, turns out i need weight in the back of my sled to make the suspension work, so stock weight actually "helps" my skinny #*$&@.
ALL my Yuasa batteries have NEVER failed with 3 going 10 years.
They are only about $80 also.
Bottom Line:
Lightweight, expensive & AWSOME=Earth-X
Affordable & dependable=Yuasa
Bottom Line:
