Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Just curious what everyone is using as far as belts and plugs for their Vectors?
I believe the proper belt is a 8DN-17641-01-00 V-Belt but want to make sure?
I have no idea on plugs however (haven't looked) what is everyone using, stock recommended or aftermarket with different numbers?
Thanks.
(p.s. if anyone knows the CDN prices for the above or somewhere good to purchase them from, it would be appreciated also)
Thanks.
theCATman
- Feb 19, 2007
- WI
- Yamaha
Belt... yep.
Plugs... I haven't changed mine yet on the Vector, but I used NGK CR9EK on the Apex, and both sleds take the same plug.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
theCATman said:Belt... yep.
Thanks Catman
Nick1945
CR8E is the stock plug for the '08 Vector.
theCATman
- Feb 19, 2007
- WI
- Yamaha
Nick1945 said:CR8E is the stock plug for the '08 Vector.
Yea, 8's are the stock plug, but 9's are supposed to be worth 2-3 extra ponies in the 3 cyls, just like putting 10's in the 4 cyls.
Hope this helps.
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
I use the NGK 8's. For the belt, I use the Dayco Ultimax 3 #138-4432 U3. The 8DN belt would not stop squeeling and is tough on the clutch surfaces.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Vectornut said:I use the NGK 8's. For the belt, I use the Dayco Ultimax 3 #138-4432 U3. The 8DN belt would not stop squeeling and is tough on the clutch surfaces.
Are you refering to grooves in the clutch surfaces?
Figured any belt would cause that but also heard aftermarket belts don't last long compare to OEM belts, so it makes sense.
I am also curious on the plugs as I have read where the higher the number also means harder starting in the cold, any truth to that?
pat the rat
- Mar 13, 2006
i run a phazer belt in mine,everybody does around here,a little cheaper and hardly any squeal when new
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
pat the rat said:i run a phazer belt in mine,
Is it basically the same belt, same thickness, length etc Pat?
theCATman
- Feb 19, 2007
- WI
- Yamaha
Irv said:Vectornut said:I use the NGK 8's. For the belt, I use the Dayco Ultimax 3 #138-4432 U3. The 8DN belt would not stop squeeling and is tough on the clutch surfaces.
The colder plugs can foul easier when starting/warming up on a stone cold engine.
I just noticed that yours is a carbed '08..... stick with the stocker #8's. The couple HP you may gain with the 9's won't be worth it if you're changing plugs all the time. Leave that to the 2-stroke guys.
pat the rat
- Mar 13, 2006
i think its a hair wider,basically the same but it don squeal,been running that belt for at least 10 000 kmIrv said:pat the rat said:i run a phazer belt in mine,
Thanks![]()
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Thanks Pat and Catman, great info!
smalltownpower
i must agree with the use of ultimax belts... although free belts if you blow one. the stock yamaha belt will pick the ski's up better on the trail, but cant take the heat if your off trail. ultimax belts break in half and result in bending the shield, and ripping the side panel off. you learn to plastic weld pretty fast haha. as with yamaha belts they shred and cause no damage. just be sure to check behind your clutch so you dont screw up the seal. we run cr8e's in all 4 of our vectors
