3UR
- Oct 23, 2016
- Pennsylvania
- 2017 Sidewinder LTX-LE
2016 Arictic Cat 7000
2012 Skidoo MXZ TNT 800
- NE Pennsylvania
Quick question I know there are two factory shims under the bolt that mounts the secondary to the jack shaft
As the belt wears and drops down in the secondary do you add shims or remove shims from the secondary?
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
add shim if belt is further than .5 mm below top of sheave. correct height is .5mm below to +1.5 mm above top of sheave.
3UR
- Oct 23, 2016
- Pennsylvania
- NE Pennsylvania
Thanks for the quick reply. Off to the dealer to get shims.
Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
Is that .5mm below to 1.5 mm above at the bottom of the cog or the top of the cog (top of belt)
- Dec 6, 2016
- saegertown pa
topIs that .5mm below to 1.5 mm above at the bottom of the cog or the top of the cog (top of belt)
Reaper
- Nov 10, 2005
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
Imo these things like the belt a little lower compared to other sleds. My apex seems to like it a tad above the top of the sheaves, but the Sidewinder seems to do better a tad below.
SWTURBO
- Mar 22, 2016
- Sidewinderturbo
If your rollers have flat spots on them then your belt will sit lower. So check those rollers.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Watch out if to much above! At idle the inside off the belt Is rubbing on the primary shaft.
- 13K
- 18K
