- Apr 14, 2003
- Hessel, Michigan
OK so the measurement is to the outside of the fixed secondary sheave? If that is the case then yes that would be accurate and I see no change if you change your belt adjustment right?
No change to the offset if you change your belt deflection.....correct. Once your offset is set, it is set.
OK then if you are measuring from the stationary sheave on both clutches the belt deflection will NOT be effected. That is where my confusion was coming from. The offset should not change at all if you are measuring from fixed sheaves no matter what you do with the belt adjuster.
Yes, measuring from the fixed primary sheave (closest to engine) to the fixed secondary sheave (sheave closest to the left side panel). The belt adjuster will make it very easy to adjust the belt deflection **After** the offset distance has been finished. Problem is, if someone who is still stock will just put the secondary bolt back in with the same amount of washers **After** doing their offset distance and their belt will be very loose or very tight. It will not stay the same if they adjust the offset distance because of how Yamaha changed the belt adjustment from the 3 bolts on the back of the secondary (previous models) to the way the Sidewinder does it from the outside of the secondary shaft.
My theory is is members correct their offset distance, they just screwed up their belt deflection in the process.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
61mm is what I liked when run up on stand
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Fleecer
- Jun 13, 2014
- 2019 SRX
If you guys are measuring to sheave nearest to left panel, what specs are you using?
Yamaha specs of .58-.61 are to inner sheave according to manual. This is with bolt tight and belt removed, as either will skew measurements.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I liked the 61mm best when i eyed it upIf you guys are measuring to sheave nearest to left panel, what specs are you using?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Sorry double post..grrr
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Manual spec...
Fleecer
- Jun 13, 2014
- 2019 SRX
Dan...thanks for clarifying.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Not sure what you mean Terry...
The fixed sheave is set to its offset distance by way of shims on Jshaft. Nothing will change that distance other then adding/removing shims on Jshaft. Belt height is a separate thing completely and is changed by moving the movable sheave in/out. Does not effect fixed sheave.
Dan
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Here is the video I did few days ago....I removed the belt guard to get a better look at alignment. I have all this stuff in my build thread always.
Dan
Dan
fourload
Mine measures 61mm without the shim behind the secondary. I guess they all vary a little bit.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Thi
sorry disregardIt will, that is why the belt tension should be checked first and then make sure the offset distance is correct.
Someone needs to make a tool that goes from the primary sheave angle to the front of the secondaryView attachment 135759
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Same as mine....It came factory with ONE shim at 62.1mm or so. And so I removed that shim, now I run 61mm right up against the circlip.Mine measures 61mm without the shim behind the secondary. I guess they all vary a little bit.
Dan
- Apr 14, 2003
- Hessel, Michigan
Dan
Correct Dan, but if someone who is still stock adds a shim to the back of the secondary on the jackshaft....there are so many washers on the main secondary bolt that when tight, it will push on the helix more causing a looser belt deflection. You need to add the same distance measured shim to the front on the main bolt as you add on the jackshaft.
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
Great information on this thread. Thanks for posting this Terry.
- 10K
