Bent jackshaft
baxter443
Age
40
2015 sr viper xtx
Has anyone removed the jackshaft and if so which way does it come out? Clutch side or chain case side? Is the clutch side bearing pressed on?
It comes out clutch side. Take chaincase apart loosen the "nut" it has 4 notches in it takes a special socket but a chisel would work. Then with the nut loose you have to hit it to release the tapered bearing collar then you can tap the shaft out towards the clutch side.
P.S. I used a 1in locking collar to slide on the shaft and hit that instead of the nut
