snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Help,anyone bent housing but not spindle? Now i am not sure that my spindle is not bent as well,but it still steers very good,even w/bent carbide,from precision skis,any comments would be a help,and does anyone know if ther is an alignment rod i can go get to set alignment,and how does one set the alignment? Thanks Pete PS very rough weekend in jackman. :?
Pinball Wizzard
If your careful you can staighten in a pess depending on how bad its bent.
Make sure you check a-arms , bolts that hold housing to a-arms and bolts that hold a-arms to bulkhead and bushings . Rode mine last year with all this partially straightened as everything was on back order. If a-arms are bent you might want to consider aftermarket and loose some weight. Spindle housing was not that expensive from dealer. Just set handle bars straight and adjust skis with about 1/8 toe out (measure distance between skis front and rear make front 1/8 inch wider). hope this helps
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Hi pinball,i havent checked out the spindle yet,but its good to know i can straighten it in a press,but talked to a dealer who said they do have a rod to send thru the spindles to check the alighment,do you or anyone know what size the rod is? :shock:
KbxSrx
rod
its the same size as the bolts that hold the skis on, use a caliper or just a ruler.
SUPERTUNER
mnm...if it ends up that you need custom fabricating and welding, I could and have manufactured many different kinds of front end components. I have a full fabricating department and could probably help you if this level of repair is required. Just check the price for replacing it first so we at least know that the repair will need to be below the replacement cost.
I also have a friend in Maine who is an excellant fabricator. Call me if you want the name and number.
Freddie
Freddie
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Thanks freedie,did i tell you how much i love your kit lol works great,what a midrange pull,and that sound cool,hey my milage did not change a bit,when we filled up i still took only $7.00 the others $10.00 he he got to love it,now this is wfo most all day,well when i wasent jumping over huge wash outs,and blowing out rear shock,oopps was i suppose to say that
pete
Micro-Belmont engineering builds and sells a billet spindle for the RX1. It was developed for endurance racing. (Soo-500) :idea:
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Hey mxz900 do you know how much for there spindle? thanks pete
I can check tomorrow, when I am in the shop
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Cool,thanks mxz900.
I can tell you the spindle housing is $196 retail! Plus the cost of the spindle and bolts. They want almost $7 for the upper bolt. I really wish I didn't know this!
The billet spindle housings are $450 pr. US money plus shipping.
I will have a price for the billet spindles themselves later today.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Wow not cheap ha mxz900,glad i already baught mine at jackman sports for $200.00 out the door.
