Snowmobile Mike
- Oct 19, 2018
- East Haven Connecticut
- 2016 Yamaha XT SE
I'm not a full throttle Guy , My Pooh FST had about 3000 miles on it before I changed for safety. I'm sure if I got in a pinch the 8DN would get me home , No ?No. Get another Gates for spare. 8dn is different size and compound.
I don't like to spend when I don't NEED TO ,I just ordered 8DN, I probably could sell it, I'd like to GET BY THIS YEAR ,I only put 600-700 Miles a year anyway since I'm in CT and have to travel to Vermont,Maine or N.Y. to ride !
Thanks for all your input it's appreciated, Thanks again Mike
Use your stock 8jp for spare and sell the 8dn. Last thing you will want to be doing ifbelt blows is messing around adjusting clutch for a 8dn.I'm not a full throttle Guy , My Pooh FST had about 3000 miles on it before I changed for safety. I'm sure if I got in a pinch the 8DN would get me home , No ?
Snowmobile Mike
- Oct 19, 2018
- 2016 Yamaha XT SE
What is NA motor ?I found similar results. 8DN good upgrade for NA motor. When I went turbo, I also got better performance going back to the 8JP length, but I have been using the Ultimax XS825 with very good results.
Snowmobile Mike
- Oct 19, 2018
- 2016 Yamaha XT SE
Another thought I just had is belt width..people have complained from the start about the harsh engagement of the viper and a huge factor in that is the belt to sheave clearance. When comparing a Yamaha belt to a gates belt, the yammi belts are narrower, not a huge amount but it is noticeable. So with a narrower belt when your weights overcome the spring pressure and engage the belt it’s not a smooth transition with the narrow belts because the larger gap between the belt and sheaves makes the clutch “slam” into the belt so to speak. Now different springs and weight profiles can alter this and improve it..but the issue still exists. The 911 cover that you can adjust that clearance would be a great option. I don’t have one nor have I ever used one, but the concept and idea is great..another great idea is simply a wider belt. If you’re into taking comparison measurements, try some different belts and and with a feeler gauge check the clearance on the primary clutch between the belt and sheaves. On mine with the gates belt and .018 gauge fits and a .020 gauge does not, that’s right in the desired range. Even with yamaha’s Stiffest primary spring with my weights and roller setup my engagement is 2300 and very smooth..but the kicker is that when it engages the sled instantly starts to move, no belt slack to overcome and no belt slipping with the gates.
Snowmobile Mike
- Oct 19, 2018
- 2016 Yamaha XT SE
What is 911 cover
BFS
- Jan 26, 2015
- 2016 LTX-LE
Red/White
NA-Naturally aspirated, aka, no turbo or supercharger. The 911 cover is an aftermarket primary cover that is adjustable for tighter belt clearance for the primary, it’s a Thunder Products item.
Snowmobile Mike
- Oct 19, 2018
- 2016 Yamaha XT SE
Thanks ,I will check it out !NA-Naturally aspirated, aka, no turbo or supercharger. The 911 cover is an aftermarket primary cover that is adjustable for tighter belt clearance for the primary, it’s a Thunder Products item.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I have not ridden mine with the MPI turbo yet. Is 8800-8900 the target RPM at full shift out? The clutching was already setup by STM but I do not know at what RPM. It still has the stock 8JP belt on it (46 miles on sled) but I just got 2 of the Gates 8JP carbon fiber belts. I have read that it will lower the RPMs compared to the stock 8JP belt. Was it something like 200-300 RPMs?
Vs 8dn gates is almost 300rpm. 8jp might be less depending on condition of it. 8800-9000 is ok. 9100 would be better!
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I was referring to the Gates carbon 8JP belt vs an OEM 8JP belt with very low miles on it (46 to be exact).
Gotcha. Havent tested that combo.I was referring to the Gates carbon 8JP belt vs an OEM 8JP belt with very low miles on it (46 to be exact).
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Seems like it would be much closer than the OEM 8DN to Gates 8JP since the OEM 8JP is already softer than the 8DN
Fast
- Sep 25, 2018
L
Are you sure this is a primary adjuster or is it for the secondary to control belt deflection.NA-Naturally aspirated, aka, no turbo or supercharger. The 911 cover is an aftermarket primary cover that is adjustable for tighter belt clearance for the primary, it’s a Thunder Products item.
Fast
- Sep 25, 2018
So what belt clearance are we looking for 10 -18 thou. From my poo experience I think the sweet spot was 10 thou.Another thought I just had is belt width..people have complained from the start about the harsh engagement of the viper and a huge factor in that is the belt to sheave clearance. When comparing a Yamaha belt to a gates belt, the yammi belts are narrower, not a huge amount but it is noticeable. So with a narrower belt when your weights overcome the spring pressure and engage the belt it’s not a smooth transition with the narrow belts because the larger gap between the belt and sheaves makes the clutch “slam” into the belt so to speak. Now different springs and weight profiles can alter this and improve it..but the issue still exists. The 911 cover that you can adjust that clearance would be a great option. I don’t have one nor have I ever used one, but the concept and idea is great..another great idea is simply a wider belt. If you’re into taking comparison measurements, try some different belts and and with a feeler gauge check the clearance on the primary clutch between the belt and sheaves. On mine with the gates belt and .018 gauge fits and a .020 gauge does not, that’s right in the desired range. Even with yamaha’s Stiffest primary spring with my weights and roller setup my engagement is 2300 and very smooth..but the kicker is that when it engages the sled instantly starts to move, no belt slack to overcome and no belt slipping with the gates.
I run mine at .008in feeler guageSo what belt clearance are we looking for 10 -18 thou. From my poo experience I think the sweet spot was 10 thou.
- 6K
