Pstn head
IMO open face are comfortable on warmer days and tighter trail running, I found on real cold days it was a little breezy but worst of all the sun visor (that overhang thing on the top) would catch wind at high speeds and I hated tucking my head down looking through the top of the goggles most of all, that would give me head ache on its own. Plus the added beauty with most closed face or modular helmets they have a built in sun shade, comes real handy for me. Plus there quitter.
WINDER1987
After reading pages and pages on the ckx titan it's a typical consensus half love it half hate it and have to try different configurations with it to get it to work back to the drawing board on a light functional helmet
krm
- Apr 22, 2016
- ny
With the bv2s ,take the front diaphram out ,this will help alot .
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
FXR Modular.
Turbo 998
- Mar 30, 2016
- LeSueur MN
- 2017 Yamaha Sidewinder LTX LE, 2014 Yamaha Viper LTX, 2001 Arctic Cat ZR800, 2- Yamaha SS440, Yamaha Enticer 250, Scorpion lil whip, Scorpion Super Stinger
- yes
I like my HJC IS Max II
sxvipersman
- Mar 19, 2006
- Dover Centre,ON Canada
- 2008 FX Nytro RTX Anniversary Edition
1979 Enticer 340
2009 FX Nytro XTX
FXR modular x2
Wamp12000
- Feb 4, 2016
- Sault Ste Marie
- Yamaha SRViper STX 137 DX
I bought the CKX Titan helmet last year. The helmet it self is great. Feels light, really enjoy the opening mouthpiece its a bit airy but I get hot when I ride even when it's -30c. I really like the helmet.
But..
The googles are a foggy disaster. The way they clip and fit the helmet is great but no matter what different configurations I tried they would fog up. I ended up using my old 509 goggles with the titan clip system and that worked good.
I called CKX and complained about the fogging issue. They told me they know about it and are sending out new goggle frames to titan helmet owners. I asked for a new frame and it was backordered so they sent me a new cheap set of goggles to get by with.
This summer they sent me a new titan frame. Time will tell if they work.
But..
DirtFarmer
- Aug 13, 2017
- Galloway, NJ
- 2009 Yamaha Nytro R-TX SE
I have a HJC BT-MAX but on cold days its drafty. I bought the Castle X lid last winter and I like that much better. It is still modular and is better for the cold days. Only issue I have with the Castle X is the condensation from my breath ends up down where the chin bar release is and will tend to freeze the latch on those really cold days. Putting your fingers on the ice for a minute and all is good but it can still be an issue. Other then that I'm very happy with the CastleX lid.
Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
When I got my Viper in 2015, I could not resist the matching FXR modular helmet, and it was a huge improvement over my previous HJC modular. It is not perfect, and I have to use the electric shield most of the time to keep it from fogging, but I am generally satisfied with it.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
If it was fogging up you had a bad seal somewhere or had the mask valve screwed up,theres just no way it would fog up all the timeI haven't had the best luck I bought a used bv2s a few years back and it fogged all the time every ride. I sold it and a few years later tried the one I currently have with the heated shield it does not fit with the heated shield or but still fogs when it is off. My main complaint of the helmet is it is too heavy for me on long rides
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I agree you are doing something wrong or you have something together wrong or are missing parts. the only thing you have to do is be sure to open the shield when you stop the rest takes care of itself have been running this lid for 25,000 miles and love it.If it was fogging up you had a bad seal somewhere or had the mask valve screwed up,theres just no way it would fog up all the time
allyammies
I bought a zox last year and there is way less air and noise coming in compared to my HJC IS MAX
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I have a solution to the bvs2 issue of mouth piece in the way. Sasquatch taught me to remove the mouth piece -rather than just let it fall forward turns out it is just press fit, simple and works, just pull it forward and off.
I suspect it fogs due to a Leaking lens or the seal does not make tight contact sealing the moisture of breath to the outside air only. I have fixed both and now never fog.
Not sure on weight issue.
WINDER1987
Was it a yellow lens you were using seen a like eveyone on the doo forum had problems with yellow lens but the mirrored lens was fine?I bought the CKX Titan helmet last year. The helmet it self is great. Feels light, really enjoy the opening mouthpiece its a bit airy but I get hot when I ride even when it's -30c. I really like the helmet.
But..
WINDER1987
My original bv2s was a fogging issue but my new one Even with the electric shield is a condensation issue it gets condensation built up inside and makes it very hard to see clearly. That is one complaint but my main complaint is the weight of this helmet for long rides at the end of the day I can't even turn my head around to see the group behind me
