rkkoeb
hello
I had reomove the plastic intake from the carbs so I could get to the battery on my 09 Apex. Is there an easy way to intstall it back onto the carbs? I want to make sure all the rubber boots are tight and on all the way on. Any videos or suggestion would be great
- Jun 28, 2004
- Clinton, Wi.
Make sure the boots are grit free, put a light coating of lubricant on the boot and the throttle body. Line up the 1 short vacuum line and press slowly and evenly and you'll feel the boots lock in to the raised lip on the throttle body. Just did this yesterday. Snug them down and reinstall everything else!
rkkoeb
That should work, thanks
i do it that way as well but i scope it or use my finger to make sure that they sit down into place properly. i have had one distort on me a few times so i always check it now.
- 6K
