Bi-xenon H4 install on FX Nytro
Dimebag
Norway, 68N
Website
www.ty4stroke.com
Hi,
Im installing a H4 Bi-xenon kit on my 08 RTX Nytro.
Do you connect the "relay-harness" or what its called directly to the battery? Or is there a place that needs the ignition on/engine on to deliver voltage?
I connected it directly to the battery. And the lights came on even with the ignition turned off...
What do you think?
Thanks.
I found a connector with 6 red wires and a linkage between these six wires. This connector had +12V with engine running. I used that one to control the extra relay before the hid lights. seemed to work great!
mphmotorwerks
If you could fill in you signature with your sled's year, model and list your mods, maybe we can help you.
