On my 2007 phazer Gt, There is a black Plug in the cover left of the gas tank cap. Is that for aux power source? If so, below there is a electrical 2 wire plug that is capped. Is it a keyed and fused power source? Looking to wire a garmin gps unit into it. Thanks, Will
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Yes it is for you accessory plug and it is fused..
I hard wired my garmin gps pilot4 right into the plug. works perfect. Also got a dash mount for it and mounted it on the riser with a homemade bracket. Sweet setup.
Thanks, Would it be better to hard wire or put the accessory plug in, any opinion??
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
Nice, just got a new lid w/ electric shield- was just gonna go off the battery for power.
Good to know now
Good to know now
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
The actual Yamaha accessory plug goes right in there, but it's not cheap. I think someone found a third party DC outlet that fits in there.
I ordered the Yamaha part, I would bet it was something like $60. I can't remember, but it did come with a cigarette lighter to RCA adapter for heated shield plug in.
I run my GPS off of it, and it works great. Easy to install. A buddy in my office found the yamaha outlet at Als snowmobile used for like $30 or so.
Good luck!
Good luck!
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
If you want to install a 12 volt outlet: http://www.ty4stroke.com/viewtopic.php? ... highlight=
You can get the outlet on eBay for half the price of the BRP one.
Hard wired versus 12v outlet:
I think mostly it depends what your planning on doing with it. Also do you already have the cig 12v cord? if you do you would have to buy the hardwire cord... For me it was only ever going to get used for my GPS so i hardwired it rite to the plug and zip tied it to my bracket, never to be removed.
Cubby
- Dec 14, 2009
I run my GPs off the 12 volt plug. Never had a problem. Plus I can switch adapters to power my video camera if needed. Hard wiring the GPS would be nicer but I like the flexibility of the outlet.
- 11K
- 14K
