jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Gates 40C4340 Drive Belt this is what I run.. I blew on of these also(43 miles).. But in all fairness I put maybe 8 miles on it and then made some hard pulls. Cut it right in half. NO fray.. Clean like a knife.. Put 300 miles on since.
I have some changes to secondary, need seat time..
Anyone know where the above belt would compare in hardness? I know it shares the same length as the 8dn.
- Apr 14, 2003
- Hessel, Michigan
40C4340 = Softer compound belt, but the Carbon Fiber keeps the belt together better. Crazy how you blew one of those up....but yours was a result of coil binding....no doubt about it.
Jafo1970
- Dec 2, 2016
- oshkosh, wi
- 17 sidewinder, doo 850
carbon fiber are softer and grip better. I use them on my boosted cat. When they blow, they blow into pieces vs the harder Kevlar belts that wind strings around your secondary.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Okay thanks NOS & JAFO helps me understand.
I had a bad brain COIL on these belts ..LOL . no pun intended
newtron
- Jan 2, 2010
- 2020 900 ACE Turbo, 2019 SRX, 2018 850 X
Received my new rollers and 37/33 today. Will install and let u guys know the results
With stock weights and springs I'm not sure why anyone would want a steeper angle on top end. My rpms drop up top which is telling me it's up shifting to quick up top.
Anyway I'll let u guys know how it goes!!
Jafo1970
- Dec 2, 2016
- oshkosh, wi
I think most of us here are running different weights with aggressive profile. Stock weights are real flat so I can understand that. I'm new to the Yamaha clutching but I've never seen such a flat weight profile. You want to load that motor as much as possible.Received my new rollers and 37/33 today. Will install and let u guys know the results
newtron
- Jan 2, 2010
That's true.
When testing and posting results, people should post there complete setup including conditions. Too many people post good results that have a totally different setup and conditions than others.
newtron
- Jan 2, 2010
Time to test!
dsimonRX1
- Dec 17, 2003
- Cascade,Ia
- www.american-iowa.com
After installing my new Ulmer rollers I still have two rollers that spin. As mentioned before I have little faith in the quality of the helix. I'm leaning on getting a straight 35 from Dalton. My RPM's were great last weekend. Went to 8900-9000 and stayed.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Newton you are all stock with this new helix. So are you studded?
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
i know changing belts will not cure whatever underlying problem may exist. But has anyone tried an XTX 5058 on their sidewinder yet? I believe it crosses over to the 8JP. I used to run XTX belts hard on my turbo cats...always changed them around 1000-1200 miles just for peace of mind...but they always performed excellent.
newtron
- Jan 2, 2010
All stock with 90 13.75 studs
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
I have an 8dn length xtx somewhere here and will test when I get a chance but I wasn't impressed with it on a turbo viper. Had the best luck with either length gates carbon over anything.
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Ben from TD had mentioned earlier that Woodys Yamaha has this figured out and it requires machining of the pocket and I think the sheave. Anyone know any more about this or them in general?
shagman
Vendor
- Feb 18, 2014
We've been machining secondary's for years for the same reason. But we're trying to find a solution with a different spring vs machining. Stay tuned.
