Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
I look at the cylinder (which is toast as well as the piston) and I see no evidence of a failed gasket! Turbo is always under pressure so the gasket would have to be gone bad to let water in but if it did it would also let pressure out. I've seen what happens when gasket fails and cylinder pressure goes out, it cuts the aluminum head and or the block. I don't see that here!
In the end the motor needs a new block that one is gone! If Yamaha does not stand behind a turbo they endorse it does not look good on them. These Vipers are full of a Mildred of problems that make the Yamaha name leave a bad taste in your Mouth. I know I would never buy one in a million years (heck I would buy a Nytro first and I don't like the Nytro). It (Viper) is just not a Yamaha! To many cooks spoil the broth!
As my buddy says you can put a Cummings in a Dodge but that don't make it a Cummings!
