adirondac blue
WITH 10 TO 1 PISTONS AND ONE HEADGASKET , what will my compression ratio be with 5, 10, 15 ,20 lbs. Is there an equation for this and how will fuel octane be calculated . Just thinking about next year.
srx74
TEST CHART
I DONT THINK THE COLUMNS WILL LINE UP BUT IF YOU START WITH 6.0:1 AT 2LBS = 6.8:1
AT 4LBS = 7.6:1
ETC...
SO 10.0:1 AT 8LBS = 15.4:1
AT 20LBS= 23.6:1
HOPE THIS HELPS
SRX74
TABLE 1: Effective Compression Ratio Chart
Static
Compression
Ratio Boost Pressure (psi)
2 4 6 8 10 12 14 16 18 20 22 24 26
6.0:1 6.8:1 7.6:1 8.4:1 9.3:1 10.1:1 10.9:1 11.7:1 12.5:1 13.3:1 14.2:1 15.0:1 15.8:1 16.6:1
6.5:1 7.4:1 8.3:1 9.2:1 10.0:1 10.9:1 11.8:1 12.7:1 13.6:1 14.5:1 15.3:1 16.2:1 17.1:1 18.0:1
7.0:1 8.0:1 8.9:1 9.9:1 10.8:1 11.8:1 12.7:1 13.7:1 14.6:1 15.6:1 16.5:1 17.5:1 18.4:1 19.4:1
7.5:1 8.5:1 9.5:1 10.6:1 11.6:1 12.8:1 13.6:1 14.6:1 15.7:1 16.7:1 17.7:1 18.7:1 19.7:1 20.8:1
8.0:1 9.1:1 10.2:1 11.3:1 12.4:1 13.4:1 14.5:1 15.6:1 16.7:1 17.8:1 18.9:1 20.0:1 21.1:1 22.1:1
8.5:1 9.7:1 10.8:1 12.0:1 13.1:1 14.3:1 15.4:1 16.6:1 17.8:1 18.9:1 20.1:1 21.2:1 22.4:1 23.5:1
9.0:1 10.2:1 11.4:1 12.7:1 13.9:1 15.1:1 16.3:1 17.6:1 18.8:1 20.0:1 21.2:1 22.5:1 23.7:1 24.9:1
9.5:1 10.8:1 12.1:1 13.4:1 14.7:1 16.0:1 17.31 18.5:1 19.8:1 21.1:1 22.4:1 23.7:1 25.0:1 26.3:1
10.0:1 11.4:1 12.7:1 14.1:1 15.4:1 16.8:1 18.2:1 19.5:1 20.9:1 22.21 23.6:1 25.0:1 26.3:1 27.7:1
10.5:1 11.9:1 13.4:1 14.8:1 16.2:1 17.6:1 19.1:1 20.5:1 21.9:1 23.41 24.8:1 26.21 27.6:1 29.1:1
11.0:1 12.5:1 14.0:1 15.5:1 17.0:1 18.5:1 20.0:1 21.5:1 23.0:1 24.51 26.0:1 27.51 29.0:1 30.5:1
AT 4LBS = 7.6:1
ETC...
AT 20LBS= 23.6:1
HOPE THIS HELPS
SRX74
Static
Compression
FastAction
peteracing
Say whattt!?
Compression ratios stay the same no matter how much boost you add!!!
adirondac blue
tHANX FOR THE INFO, NOW how does that relate to octane.
16 to 1 should run what octane? etc. etc.
sledheadgeorge
Turbo Tim
sledheadgeorge said:
Wow I think according to those charts me and many others should have blown up our engines a long time ago !................The charts don't take in to account how efficient these Rx1 engines are .
